ENTRIES OPEN,
TIME TABLE
4:00PM GATES OPEN
5:00PM SCRUTINEERING
5:00PM DRIVER SIGN ON
5:30PM DRIVER BRIEFING
6:00PM START TRACK ACTIVITY
10:00PM END TRACK ACTIVITY
SPECTATOR
everybody is welcome to spectate at our events entry is FREE
we have an associate membership package available for spectators
costs $40 you get t-shirt, sticker, membership card & a free drink at all our events
you can apply for this on the day.
SCRUTINEERING
your car will need to pass scrutineering
brakes, brake lights, seatbelts/harnesses, windscreen wipers all need to work properly
drivers seat must be secured properly all wheel nuts must be present
you will need a secondary bonnet restraint if you dont have one just bring a short rope & the
scrutineer will assist you installing it
DRIVER/PASSANGER
to drive you will need appropriate clothing (non flamable)
your clothes must cover you from neck to wrists to ankles
closed shoes must be worn
and only helmets with the AS1698 sticker affixed can be used
COST
$100 if your a member with driftmob & have a cams license
$120 if your not a member with driftmob & have a cams license
we can issue you with a cams license on the day
$40 if you want to be a passanger on the day
if you want to become a member you can apply on the day
HOW TO PAY
entrants can pay on the day but we recommend prepaying to secure a spot
at this stage we can accept cash & eftpos if you want to pay on the day
PREPAY
deposit total amount and bring your reciept with you on the day
no prepayments after 11th april
ACCOUNT NAME = DRIFTMOB INC
ACCOUNT NUMBER =259589
BSB =032372
BANK =WESTPAC
just a quick run down for the day,
we are allowing passengers in all car's roll cage is not nessasary
we are track time orientated this means we will not stop for lunch
if you have any questions please ask
cheers.
the driftmob crew.
Edited by DRIFTMOB
https://www.sau.com.au/forums/topic/356990-drift-night-13th-april-2011/
  • 3 weeks later...
This is for everyone! I had my first drift day on the dry peanut track, and it was great. It's nice and tight, fairly slow, so it's perfect for beginners. Considering coming to this one myself, depends if I can get all my adjustable arms and an alignment done in time. :)
I have one question though - will the wet pan be running too?
Cheers, Brent.
great night lasted one round got some sidewayz action, but f**ked the car rear left wheel the nuts gave way and yea now need new hub control arm studs and maybe a diff... new rear qaurter panel but apart from that disaster It will all be good! definatly investing in track oreinted car... so I wnt b left without a car when shit like this happens
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
