Hi all
Just after some advice on something thats been an intermittant problem on my 34 GTT
out of nowhere (meaning i havnt touched anything) the power seems to drop when the brakes are applied, or even more obvious when the indicators are used.
in some cases im just sitting at the lights and everything goes dead
i know theres a short somewhere.. but where do i begin?
https://www.sau.com.au/forums/topic/356998-voltage-droppinglights-dim/
just did then. the car has been sitting still overnight so nothing could have shifted around (loose wiring) and it seemed fine when it came to test it.
the voltage when started was at 14.5v
only thing i can think of is when it happens again, pull over and give the alt a whack
Hi all
if its showing 14.4 running and stays that high, your battery is farked most likely , the current holding on the battery is gone.( interenal corrsion of the plates ) your battery might say 12v off, but when you crank it it's dead, NO AMPS (Current )
or corrsion on the terminals ?
loose bolts at the terminals?
if you still have one of those little ass battery from japan , bin it and buy a real one . DO NOT WHACK YOUR ALTERNATOR, it could only just damage it !!!! the old school hitting the starter fix doesn't work on it
you can spray it out with electronics cleaner IF its oiled up like hell, but beware , some cleaners can melt plastic /paint or ruin the alternator is used wrong or while running.
ground your battery with an additional 4ga cable to the bracket bolts holding the alternator and zip tie the wires to keep them from hitting anything, your car will thank you and charging will be much better.
power electrons goes from negative to positive, not the otherway around like common thinking sugguests.
the grounds for 90% of everything in the rear of the GTT are behind the rear seat back on both sides connected in a star fashion. doubt its a ground unless at the battery or something new installed wrong ?
agree with most but not this bit, if the engine starts ok and the problem is only intermittent i wouldnt think battery. the alterator should be able to supply those sorts of power levels without voltage dips due to indicators or lights even if the battery was stuffed. i would be turning a/c fan on max, all lights on etc then check the voltage at battery and alternator. should be 13.5- 14.4ish and less than 0.5v difference. and yes do NOT whack the alternator.
a farked battery will do that. doesn't matter what the charge voltage is. if it has a collapsed cell (IE short) then it will take an alternator with it.
don't belt the alternator...
yes my money is on dead cell or weak one,
and or corrosion on the terminals, loose bolts holding clamps.
voltage regulators fry when the cell shorts, or jump starts gone wrong.
they can go the other way too, and overvoltage the car as well, which kills the ecu, battery, fuseable links, relays, etc. and other lovely items. high rpm tends to do that one, my bridgeport RX7 killed off many alternators some lasted 1 rev to redline before death . just a good thing it was a weber not fuel injected car.
i still stick by my comment, not saying your wrong about the battery as wierd things happen and we are only diagnosing over the interwebz but i think if there isnt any shortage of power starting the car, then i would imagine indicators should be piece of cake. dead cell batteries usually have a standby voltage around 10v so will start but sound sad.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
