Hi all,
I recently ordered some CP RB30\26 9.0 to 1 CR 86.5mm pistons and when they arrived I was surprised to find that they don't have any valve reliefs cut into them. Is that correct ? Bit worried as I'll be using 10.8mm lift Kelford Cams with them.
The build sheet is :
http://img861.imageshack.us/i/cppistonsspecs.jpg/
Heres a picture of the pistons :
http://img853.imageshack.us/i/cppistonspics.jpg/
Edited by mambastu
I maintained the 8.5:1 scr on my rb26/30 build and was running jun 10.5mm lift cams, and the pistons had fairly serious cutouts in them. Pics are in this thread:
If it were me I'd definitely be checking with plasticine - once it's all put together and timing set up how you want it of course you would be carefully turning it over to check no interference but you'd want to know what kind of margin there is for stretch etc, espc if you're playing around with the duration of lobles and/or timing with slider cams etc.
But then I'm a fairly risk averse person.
http://www.skylinesaustralia.com/forums/topic/275548-andrews-r32-gtr-bolt-on-build-thread-phase-i-of-my-mods/
Actually drifticon I saw your thread and was keen to seen a photo of it with the bonnet closed, just because I'm yet to see anyone else space the subframe and was curious to see how close to flush the bonnet closes,
Cheers Brett
Sorry for the hijack
It's not very flush at all - we had to turn up spacers out of alloy, which are 20mm thick. Looks a bit agricultural.
Reasonably confident that it's the "twin turbo" pipe that is causing the problem, rather than the timing belt cover. Im going to a single turbo eventually so assuming I can get a manifold that sits the turbo low enough, it should be possible to get custom piping that clears the bonnet and also allows strut brace to be fitted.
[/hijack]
Cheers Brett
  • 1 year later...
Just getting ready to build the engine (at last !) and trying to work out deck heights, compression ratio etc.
The build sheet for the pistons lists a dome height of 0.055", does anyone know what that equates to in CC ?
I'm aiming for a 1mm squish clearance so I assume, as I'm using a Tomei 1.2mm 88mm head gasket, they need to protrude from the block by .2mm. Will be CCing the head shortly as its been skimmed in the past.
Cheers
Stu
  • 1 year later...
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
