So last week i drove up to a near city, estimated about 25 miles away from home to pick up my cousin up and go to a local junk yard and maybe find some goodies laying around the yard....
we stoped at a local autoparts to rent a tool , as we head back to my car, the car wouldnt turn on. it didnt even turn over , as if it was compleatly dead!
it did click when i turned the key...sound comming from my strarter. as i opened the hood i noticed a realy bad sulfer smell, like rotten eggs. and noticed it was from my batterie. aww geeze my batterie just took a crap. checked all the fuses to make sure everything was ok and not just a blown fuse.... fuses are good.
installed new batterie and car started right up like a champ.
we continued with our day driving around all day looking for parts in diffrent citys, car drove normal and got us home. (drove about 100 miles on the rb that day.)
continued to drive the car for about 3 more days and one day after work i went to turn my car on and it was compleatly dead once again? and that clicking soundcomming from my started once apeared evrytime i turned the key......so i had my brother give me a jump...car started right up. as soon as i took the jumper cables off it seems to idle a little odd for about a minute and the car slowly dies after.
evrytime ive jumpstarted the car it does the same thing and wont turn on willingly on its own as if its compleatly dead evrytime? it just clicks....
i changed the battery and it worked for a few days no problem.
i changed battery terminals.
even put my brothers maf on to see if it was something with the air fuel mixure but it did the same thing...noting changed....(he has RB25 aswell in his s13)
now i think my starter is bad, and my altenator is bad because as soon as i take the jumper cables off, it dies after being on, on its own for a minute or so.. then dies like there not enogh voltage to keep it alive.
all the fuses are good.
car runs good when hooked up on jumper cables.....? what could be causing this?
any ideas guys???
https://www.sau.com.au/forums/topic/357126-need-help-car-suddenly-is-dead/
Probably dead alternator. How it died would be debatable.
Possibly something in the starter solonoid shorted the starter cable (hence giving your battery a horrible odour) - Then the short also may have somehow killed the rectifier in the alternator.
I'd be testing by running the car on jumper ldeas, measure the voltage across your battery, keep measuring while you remove the jumper leads, and observe a change in voltage.
If the voltage drops, you have alternator problems.
Testing the starter would be a lot harder since it's an intermittent fault.
