For Sale:
$10.900
Prestons NSW
Mitsubishi FTO GPX V6 MIVEC
This is a great example of a well kept and looked after vehicle.
This car has a excellent interior and exterior for its age, the car has traveled approx. 89 000km's without any problems.
This FTO GPX has a V6 MIVEC engine which enables great drivability in any situation with plenty of poke for the car lovers out there.
The car was regularly serviced and maintained as per manufacturers recommendations with premium motul oils and bosh platinum spark plugs.
This car has a full silicone intake duct with a high performance Saber air cleaner and chrome thermo resistant heat shield, the air cleaner is fire resistant and deemed to be road legal in that respect.
The full exhaust system was developed by Mitsubishi performance work shop MEEK, the full tune length extractors/headers with a 6:2:1 into a single high flow catelic converter which is further guided into a Lukey performance rear end with classic race finish chrome outlet. The engine mechanical tappet adjustment was checked by Mitsubishi rallyart performance mechanics at Mitsubishi service two years ago and were perfect with no adjustment needed, every FTO with [MIVEC v6] vale set up has to have this check once every 6 years or so to assure proper gap adjustment. The ecu on board computer on this car has been upgraded with a LINK performance ecu, which has done magic for this type of car. The aftermarket Rasin volt stabilizer system on this car has all electrical components protected and delivers a great voltage signal. The Link ECU allows adjustment of the air fuel ratio mixtures, this was installed and dyno tuned by leading performance workshop PULSE racing in Menai NSW. This car makes more power and torque than many Honda Type 'R' racing engines out there. The suspension system has been upgraded with race KYB shock absorbers and King springs for the desired ride height and handling, 17 inch Racing alloy wheels, this delivers excellent handling without compromising comfort, it just sticks to the road, it is not too low and climbs shopping speed humps without problems. The interior has been tastefully upgraded with the standard dash mount gauge pods upgraded with white faced air fuel ratio gauge and water temp gauge to keep the engine well monitored and also a carbon fibre gear-shifter, the very expensive Pioneer MP3 stereo system with MB Quart font speakers and splits also Sony explode 6 by 9 deliverers great sound. This car has full digital climate control and comfortable bucket seats. I only ever used BP98 premium fuel. This is a excellent car, i have owned it for several years and it still looks just as great as the day i bought it, i have invested a lot of money and time with performance upgrades and the new owner will be very happy with it, the car drives good and sounds great, with minor wear and tear as all cars of its age, i would consider this car in much better condition compared to many for sale out there.
https://www.sau.com.au/forums/topic/357268-mitsubishi-fto-gpx-mivec/
  • 5 weeks later...
How are people meant to find your car on carsales to view photos?
bump..!!
no pics, no link to pics
useless adds like this should just get deleted as they are pointless. nobody will buy this car without pictures
at 11k asking price, those pictures better be magical as well.
  • 2 months later...
Haha easy buddy..^
You are a bit of a tool saying that in someone elses post, if you have a recomendation then you can recomend it to me via PM you NOB..
The car is Magical.. it is a silver imaculate FTO .. no scratches or dints, but i will put pics up.. just to shut you up.. winge winge winge,,, hahahha
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
