Custom Cams For 3 Litre
Semi-correction to my blanket statement that you can't bend rubber hoses. It seems that you can get most of a result, by doing as this guy does. I wouldn't promise that the bends will stay in the hose forever. I think if I found they wouldn't stay, I'd get a larger hose and cut some 90°s out to go over the bends I wanted to be in the smaller hose, as a reinforcement.
Just a heads up. Mine has just failed. When i turn the car on it just reboots everytime then the word "Android" shows up then goes to a black screen. I've aksed the company i got it from for some help but it's passed their 90 day return so they wont help. I have to swap back to my old system this weekend 😭
Does the car have to stay auto? If so, you might be looking at a ZF swap in future. -
Yeah its tuned relatively conservatively being dynoed at 525hp with every bolt on and top end of the motor built wtih HKS vcam and springs etc.
Probably. But keep in mind that all Joshua was saying that because of things like timing scatter, and many other related and unrelated things, tuning too aggressively should be avoided. Hence why both he and I said that fitting the cat shouldn't cause you to suddenly fall into the danger zone.
