ECCS diagnostic codes 1988-1994 models
JezR31
 Share
this is my first thread :)
This is for nissans from 1988-1994, altough i think its the same for 1994 models and up
ECCS has 5 modes :
Mode 1 - Exhaust Gas Sensor monitor.
When the engine is warm (closed loop) the green led turns on for lean, off for rich. It should alternate. When it is cold (open loop) it will be either on or off.
Mode 2 - Mixture ratio feedback control monitor.
During closed loop operation the red led should turn on and off simultaneously with the green led when the mixture is controlled within the specified values. During open loop the red led stays on or off.
Mode 3 - Self Diagnosis. See below
Mode 4 - Switches On/Off diagnosis.
The inspection lamp monitors the idle switch portion of the throttle valve switch, the starter switch, vehicle speed sensor an other switches with an on/off condition.
Mode 5 - Real Time diagnosis.
Same as Mode 3, but it flashes the errors as they occur.
To select the various modes :
nissandlc.gif With the ignition ON take a small screwdriver and turn it clockwise. the LED's will flash together, first once, then pause, then twice, then pause, then three times. When this happens turn the screwdriver counter clockwise. The ECU is now in mode 3 which reads out the fault codes on the LED's. It will cycle through all stored fault codes.
Red LED = 10
Green = 1
If the red led flashes 4 times and the green one flashes 5 times that means you have code 45. It will repeat this if this is the only fault. If there are more faults it will flash all the faults and repeat.
The ECU will reset when you turn the ignition off.
11 - Crank Angle Sensor/Camshaft Position Sensor
12 - Air Flow Meter
13 - Engine Coolant Temperature Sensor
14 - Vehicle Speed Sensor
21 - Ignition Signal
22 - Fuel Pump
23 - Idle Switch
24 - Throttle Valve Switch
25 - Idle Speed Control Valve
26 - Boost Pressure Sensor
27 -
28 - Cooling Fan Circuit
29 -
30 -
31 - ECM
32 - EGR Function
33 - Heated Oxygen Sensor
34 - Knock Sensor
35 - Exhaust Gas Temperature Sensor
36 - EGR Control-Back Pressure Transducer
37 - Knock Sensor
38 - Right hand bank Closed Loop (B2)
41 - Intake Air Temperature Sensor
42 - Fuel Temperature Sensor
43 - Throttle Position Sensor
45 - Injector Leak
47 - Crankshaft Position Sensor
51 - Injector Circuit
53 - Oxygen Sensor
54 - A/T Control
55 - No Malfunction
63 - No. 6 Cylinder Misfire
64 - No. 5 Cylinder Misfire
65 - No. 4 Cylinder Misfire
66 - No. 3 Cylinder Misfire
67 - No. 2 Cylinder Misfire
68 - No. 1 Cylinder Misfire
71 - Random Misfire
72 - TWC Function right hand bank
76 - Fuel Injection System Function right hand bank
77 - Rear Heated Oxygen Sensor Circuit
82 - Crankshaft Position Sensor
84 - Automatic Transmission Diagnostic Communication Line
87 - Canister Control Solenoid Valve Circuit
91 - Front Heated Oxygen Sensor Heater Circuit right hand bank
94 - TCC Solenoid Valve
95 - Crank Position Cog
98 - Engine Coolant Temperature Sensor
101 - Front Heated Oxygen Sensor Heater Circuit right hand bank
103 - Park/Neutral Position Switch Circuit
105 - EGR and EGR Canister Control Solenoid Valve Circuit
108 - Canister Purge Control Valve Circuit
111 - Inhibitor Switch
112 - Automatic Transmission Speed Sensor
113 - Automatic Transmission 1st Signal
114 - Automatic Transmission 2nd Signal
115 - Automatic Transmission 3rd Signal
116 - Automatic Transmission 4th Signal
118 - Automatic Transmission Shift Solenoid Valve A
121 - Automatic Transmission Shift Solenoid Valve B
123 - Automatic Transmission Overrun Clutch Solenoid Valve
124 - Automatic Transmission TOR Conv Solenoid Valve
125 - Automatic Transmission Line Pressure Solenoid
126 - Automatic Transmission Throttle Position Sensor
127 - Automatic Transmission Engine Speed Signal
128 - Automatic Transmission Fluid Temperature Sensor
tell me if im wrong
Thanks Skyline_boy, great info.  It didn't appear straight away because we moderate all posts in this section :)
Some ECU's have only 1 led and some, eg mine, have none, The error codes are also flashed by the dashboard engine warning light
  • 2 months later...
  • 8 months later...
  • 3 months later...
I know I am digging up an old post but what is the code retrival procedure for an R32 GTR ECU with only 1 LED? And i dont have any Diagnostic/Consult plugs as this engine is in an R31.
  • 5 years later...
If anyone is still wondering, if you have only one led or none(uses the check engine light instead) two long flashes followed by one short flash means error code 21, ie long, long, short.
So it is pretty much the same as if you have two LEDs.
  • 2 months later...
So I followed the instructions given above on my series 1 r33 gtst.
my ecu only has 1 light, not exactly rocket science to work out how to read that - however.
I turn the ignition to "on"
turn the screw on the ECU clockwise, red light turns on and stays on (no blinking - that isn't what i was expecting)
so I turn the screw back a touch, and it gives me 5 long 5 short aka 55 = no errors logged. (guess I'm in mode 3)
feeling rather proud that I have no ecu errors I continue the instructions given and turn my ignition off.
When taking it for it's first drive after this, I was maybe 1km from my house before the check engine light starts blinking at me.
I pulled over popped the bonnet(motor running), nothing seemed out the ordinary, get back in the car.... no check engine light... hmmm
Cautiously, I started back in the direction of home and before i was into 2nd gear the light is popping on and off... sometimes a short flash other times it just comes on for a few seconds, no obvious pattern - I'm certain it's not giving me error codes in real-time.
I've reread and redone the whole error code retrieval a couple of times, right now I have the battery disconnected trying to reset the ecu.
Has anyone had something like this happen?
I really need to get this sorted, I will not drive the car while it's telling me there's a problem - even though it seems to be running just fine.
any advice would be greatly appreciated any questions happily answered. PLEASE HELP
Edited by Raven33
after resetting the ECU the engine check light stopped doing it's thing.
Something that I noticed was, when the motor was off with the ignition on and you have all the warning lights in the dash light up - the engine check light was NOT on while I was having this problem.
After the ECU reset the check engine light came on with the ignition and turned off with the others once the motor was running.
So long story short:
If you check your ECCS codes and then have the engine check light flashing somewhat randomly while driving, just reset the ECU before trying to locate a problem with the motor.
Disconnect battery, pump the brakes a couple of times, turn the headlights on if you want, reconnect the battery once the car has been sitting for 24 hours (I only waited 2 hours, might be best to wait 24 hours)
If you've reset the ECU and still having the engine check light come on and off then I'd suggest you have a bigger problem.
Hope this helps someone.
~Raven
  • 3 months later...
  • 4 weeks later...
tried to search but it came up with a copy an paste of the list above in the threads i've seen, what i want to know is error 13 and 98 both being "Engine Coolant Temperature Sensor" which one is the ecu sensor and which one is for the gauge on the cluster?
Edited by Dan_J
 Share
