$36,000
Maybe intrested in swaps + cash
Fresh engine 2 events since rebuild aprox 5,000km
Car currently running 365awkw with over 1400nm toque
Current tune is for mid range power delivery will make 400kw on power tune.
Everything has been done that needs to be done and all parts are basically new or are new!
Car has current 3 months SA rego
Comes with lots spares and std parts like std exhaust system.
Car as been modified from standard by myself and I have been the first owner of the car in Australia.
Top competitor in legend of the lakes hill climb also took out the overall dyno challenge at autofest 2010 Mount Gambier.
Car has barley been driven since build and is going to waist. Car was built on the basis of doing hill climbs and some track work but never seen a track yet.
Engine
Arp main bolt’s
Arp head studs
Arp rod bolts
Tomei Metal head gasket
Tomei Metal intake gaskets
Tomei Metal exhaust gaskets
ATi 1000hp balancer
Trust Oil pump
Tomei oil restrictor
Eagle rods
CP pistons
ACL race bearing throughout
Trust sump
Gready under drive pullys
N1 water pump
Nismo thermo stat
SARD 800cc
Head ported and polished
Tomei poncams B
Tomei pro double valve springs
Tomei titanium valve retainers
Nismo fuel regulator
Silicon high temp water hose set
HKS twin spark ignition
Gready solid radiator hoses
Gready oil cooler/ filter relocation
Custom hard piping kit intake/cooler
CoolingPro Intercooler
Blitz dual bovs
Twin Z32 Air flow meters
PFC Pro version with launch control and ignition cut
Braided turbo oil and water lines
Yellow jackets coil packs
HKS cam gears
OBX split dumps
Std turbo manifolds with major porting
Garret -5 turbos
kokamoto race twin 3" pipes tuned length from dumps back
justjap circuit oil catch can into a secondary custom catch can
Apexi air filters
Custom 3 core alloy radiator
Custom sure tank with bosh 044
Drivetrain
Nismo Engine mounts
Nismo Gearbox mounts
custom cusco 30mm swaybars
project D rear cradle solid bushes
project D steering rack bushes
Twin place ORC 702 clutch
Nismo short shifter
Rear adj upper camber arms
Upper front adj camber arms
Hardline caster rods
Hicas lock out bar
Front Two peice slotted rotors
Slotted rear rotors
Yellow stuff pads all round
Project mu drift handbrake pads
Braded brake lines all round
Cusco brake stopper
Tein coilovers with full in cab control
Rear LSD shimmed
Interior
6 point molly bolt in cage with full padding wrap
Nismo 320 dash
Nismo Gear knob
Fire extinguisher
Quick release steering wheel hub
Momo race wheel
Defi Gauges Oil temp/ Water temp/ Boost bar
Led shift light
Greedy turbo timer
Profec b boost controller
Exteriour
Front Bar on speed clips for quick removal
Top secret carbon rear defuzer
Top secret front add on lip
F1 carbon mirrors
BeeR carbon rear spoiler
Top secret carbon bonnet
Top secret front splitter
Tomei headlight air duct
Zigen 18x9.5 rims on 265x35x18 semi slicks advans A048
I am located in Melbourne and car is currently here.
I have driven the car a total of about 5 times this year and has always been garaged under a cover.
Engine was built a year ago by Protek Automotive in Preston and last tune was done 3 months ago with a new HKS twin spark system.
Also this is a ser3 r33 gtr so it has the extra bits std,
tuffer gearbox
xeon headlight
red interiour inserts
dark carbon instumental pannels
n1 front bar intakes
this was the last year they where made 1998
call or msg 0416250596
Also Have the following RAYS NISMO rims 18x10 at an exta cost can be neg on finally price.
The car when it was std.
Ready to drive home or straight to the track heaps of goodies and heaps of realiable all day power.
tuned on BP98
Perfect time to buy as the Aus world time attack entrys come out!
Ready to race just jump in and go!
Decided to drop the price as I have a business deal that needs some money invested into it.
So $32,000 for a quick sale!
will be taking the car to the sau vic dyno day this weekend so if your intrested come down and check it out.
Has to go guys
Didnt make down to the SAU Dyno day got held up at PRO Flows dyno day.
Car ran in 2wd and made 402.7rwkw will post up dyno sheet soon.
dont know why no-one is interested? massive budget spend, massive brand name parts list?
worried about getting it rego'd in vic? i just about all the std parts to do it?
have std bonnet change that,
have std wing blade change that,
have full std exhaust system so change that,
have std ecu and afm's change that,
remove the bolt in cage,
get rwc and your done put it all back on?
If you from SA its right to go and drive it home!
Im really interested in a e46 M3 so looking for a swap or a nice s15 with leather + cash.
Edited by Travis Trayhern
http://www.fullboost.com.au/video.php?id=613&startRow=0&endRow=10&page=1
Second car in the video.
not the most powerfull car there but it is a circuit car not a drag cal like all of them.
  • 3 weeks later...
still up for sale, car just sitting at protek over in preston feel free to go check it out and ask them about it and its build :)
interstate buyers welcome also if you need to fly in im happy to pick you up from the airport and show you the car, if you want to drive it home will throw in a free set of earmuffs haha
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
