Hello,
I am wrecking an R33 Series 2, the car is white and automatic.
Parts;
Front bar (no nismo lip & only one fog lamp available) - $250
Series 2 grille, brand new and just painted white - $200
Front guards - $100 each
Engine, 150,000kms from memory and runs well - $500 ONO
Gearbox - $300
Steering wheel with airbag - $250
Passenger airbag - $250
Both airbags as package - $400.
Have all interior, doors etc, msg me with what you need.
I will sell the whole wreck untouched for $2.5k ONO - the car has damage at the front, radiator support, LH rail and skirt.
Available on SMS also, 0402559887
Located south of sydney.
Cheers
Edited by braadz
https://www.sau.com.au/forums/topic/357393-wrecking-r33-series-2-96-model/
Hey mate, can you please get a pic of the Dash faschia (Dash trim piece that goes under speedo, around to air con controls etc) Any unwanted holes, cracks, peeling etc?
Cheers Matt
  • 1 month later...
  • 6 months later...
  • 3 months later...
  • 4 weeks later...
  • 3 weeks later...
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
    • I'm far from an expert, but for sticking bits of metal together occasionally I got a MIG, the biggest one I could get with a 10a plug (because while I have some 15a GPOs around, they are not everywhere).  Also, because I get through SFA, I just buy the small disposable gas bottles at Bunnings, I'm not opening a BOC account to get through 1/10th of a full size bottle each year
    • FWD is different though.
    • Ignore the BOV / recirc valve question. You have an NA and shouldn't have one. If there magically is one though... It should be removed, though it shouldn't really effect it in the way one will for a turbo motor with it venting to atmosphere while running an afm.
