Step 1
Purchase wheel stud from any autoparts store..
Step 2
This is for the rear wheel, for this the car will need to be in neutral with the handbrake off so make sure its not going to roll away by chocking up wheels then jack up rear of car and put on jackstands.
Step 3
Remove wheel
Step 4
Remove caliper by undoing these 2 bolts
Step 5
Remove disc, if it doesn't come off easily find 2 bolts that fit into the holes here, then turn them until the disc pops out
Step 6
If you line the stud up with this gap then give it a good whack or 2 with a hammer it will pop out.
Step 7
Put new stud in, bit tricky but can be done
Step 8
Now you have to pull the stud through, its a tight fit, to do this I put a large nut behind the regular nut. Then tighten it until the stud pops into place
Step 9
Then put it back together, give caliper a clean with brakleen or some degreaser, put a quick coat of paint on the disc and its good as new
Step 10
Replace shiny wheel after a solid hour of polishing >_<
https://www.sau.com.au/forums/topic/357402-replace-broken-wheel-stud/
Thanks alot man!
I'm deff going to try this one out.
But quick question, is it possible to pull the new stud all the way out when your pulling it through the hole? Or is there something to stop you pulling it all the way out? like a grove or a stop on the end of the stud your putting in.
Thanks alot man!
Yeah it will stop it has a flat end on it..
Awesome tutorial I thought I had to replace the entire hub but this is much easier and cheaper cheers.
When I pulled it apart I was thinking I may have to take the hub off too
Actually if you look in one of the pics i had taken the hubnut cap off, i went looking for a giant socket to fit but couldnt find one :D
  • 2 months later...
  • 3 months later...
  • 6 months later...
  • 3 weeks later...
How tight should the new stud be going in????
Mine was so tight i ended up stripping thread (while using the nut to pull it through) luckily i purchased an extra, so i went onto a different hole (i have 3 to replace) but that was the same so i stopped before i ruined that one too!
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
