I am in Auckland,NZ and very keen on a set of these.
I have front camber/castor arms as well as the rear bolts and BC Gold coilovers, but it's still a boat in the corners.
It would be great to get some control with these.
Edited by nz_monkey
Daleo's bracing, and the Superpro compression bushes give a much more pronounced handling improvement than the sways imo. Not saying 'don't get em' but increasing the spring rate isn't going to improve the ride much, quite the opposite. I would be doing the lot...
Oh, I have. :P
  • Like 3
These are currently not a stock item with Whiteline, but this too, is hopefully going to change soon.
I have shipped bars to NZ, generally my prices are better even once shipping is included.
I'm on the case with this, I'll keep you posted.
  • Like 1
  • 3 months later...
I have been chasing for months now; and they have basically told me that there are no plans to re-introduce them.
I presented a case to support their requirement of a minimum order, that I felt I could guarantee, but no.
I even told them that Superpro/Fulcrum are doing a bar set now; but they don't appear interested.
I have lost my direct contact in R&D, and my supplier doesn't get the kind of detail regarding supply that he used to receive either.
I'm sorry guys; I tried. I really tried.
You could go to Fulcrum, but I have no way to get good prices on their product, and they keep no stock; EVERYTHING is made to order, with a minimum 6-8 week lead time.
Thanks for trying for us Dale. For everyone looking for bars I grabbed a set of Superpro from ebay (from these guys: http://stores.ebay.com.au/Online-Performance-Autos). They took about two weeks to get them too me, was advised straight away about the delay. Haven't fitted them yet, cars in getting some work done.
Cheers
Cam
Hey Dale,
No problem, thank you for trying your hardest best. You shouldn't feel bad about it. I just upgraded my swaybar mount bushes until I find some bars. Cheers Sonny
Edited by M35
SuperPro (I assume) on eBay at the moment:
Fronts (AU $238.50) - NISSAN STAGEA M35 AWD - 2001-2007 Front 33mm HD Blade Adjustable Sway Bar
http://www.ebay.com.au/itm/191272490435
Rears (AU $214.65) - NISSAN STAGEA M35 AWD 2001-2007 Rear 20mm HD Blade Adjustable Sway Bar Swaybar
http://www.ebay.com.au/itm/360995089393
Would need to confirm if they come with new mount bushes too...I again assume they would.
  • 4 months later...
Hi All,
Just to confirm and somewhat summarise this post from its beginnings...
What is currently the best available option for upgrading the suspension to stop the Stageas handling like a boat?
Have recently bought my 2001 Stagea (NM35) 250T RS Four and would like to sort it early next year.
Regards,
Toby
SuperPro is basically your only option in Australia now, Whiteline no longer manufacture bars for the NM35; and are not interested in reassessing that decision.
Lol... Rare!
Dale, ages ago, we did a group buy. I think it was selbeys or someone attached to that name? That's what I've got. Anyway, would that be an avenue for people wanting bars to explore again, or they out of business now?
Alex, Todd Selby was the guy I used, his business is Signature Swaybars.
He's still in business, but he moved down the South Coast.
The issue will be price IMO; he was around $300 per bar, and I'd imagine that will have increased in the meantime.
For the same money you could do the SuperPro bars. Maybe Scotty will chime in; I know he does a fair bit of trade with them nowadays; perhaps a group buy or bulk order could be placed?
I know they only manufacture to order; they don't keep stock on the shelf.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
