I hate you so much at the moment Craig. At least I know mine are on the way!
Gold......my wife run's the club if you want membership!
Got the road free to myself this morning after getting past an AU XR8.....pfffft!
A little bit of a play through the last couple of corners......front end react's perfectly....Nankang's react baddomokun.gif..........lol......XR8 must have been on retread cross-ply's......
Haha maybe I should get her to pull your sway bars off for me :P
Get some new tyres! Nankang's are RUBBISH! And in the wet it's like skating on steel wheels. Worst tyres this side of retreads.
totally agree...Nankang's are SHIT!!!!!.....first set of crap tyres ever!!!.....but they are also the first set of tyres that I have had on the car for more than a year....and they have coped a hiding!
Might be back to the trusty old Falken's in a month.
I'll admit, I had some "help" from my 3 yr old son today; you guys like sticky tape, right?:whistling:
Mine arrived yesterday. Two days to arrive :thumbsup: and now it looks like it will take three days to unwrap! Your 3yo son did a very good job with the tape.
Thanks again for all your effort Dale :worship: - can't wait to put them on, although that could be a week away!
Mine arrived today also. My son unwrapped them & he was like a kid in an erm auto parts store lol.
There was only one minor issue. A bag of the grease busted open & the bag that was around that was also split so I've got black stuff all over the place :yucky:.
I don't suppose there's anything too special about that grease? I've got a few different types of 'standard' grease around if I can't squeeze enough out of the 2 packets supplied.
Mate, they really look great. All those gold anodised fittings make it look very pro, and even match my TV tuner lol. Thanks again Dale.
I fitted the front bar last night, I had some issues with the gold clamp rings, they seem to hit the chassis when clamped to the bar and only allow a small amount of bar travel. Has anyone else hit this problem? I was worried it would cause load on the links.
I only had to file a bit off the lower part of the clamp to make it work though...
Jules did tell me he'd had a similar issue with his, which manifested in a light knocking noise; but that Whiteline had sorted the issue. I believe due to the large diameter of the bar, the orientation of the collar will be fairly critical.
If you are installing these with the car on ramps this should be fairly straight forward, if on stands, it's a little more complicated. Scottys solution is a fairly simple one; grind or file the area to gain some clearance.
If anyone has a problem; please let me know.
Cheers, Dale.
I just fitted Ironpaw's bars today, same issue with the front locating clamps. I just filed a few mm off the upper half of the clamp and it gave me back all the travel the bar would need. They have to be clamped hard one side so when you lower the car they sit central giving the bar plenty of clearance. Other than that they are great.
We set the rear bar at maximum, (closest hole to the mounts) and the heavy front bar on the softer outside holes. How do they feel mate?
Cheers, Dale.
My clamps were sweet. . but I know they did shave a bit off them at time of fitting. . the knocking noise was an issue with the powder coating and bolt diameter which created the knocking but was all sorted. But mine was the R & D car so it was expected, the things I force my stag to do for others. . whistling.gif
I guess variations in cars would account for mm differences. .
Mine rock and I love them. . my settings are hard front & medium rear. . . . which Whiteline found offered the best results for street conditions.
It's f**king sweet as! Now I understand the "corner devouring" thing. Most of the body roll is gone. Cornering and the turning seems much sharper and precise.
Almost got self killed trying to take a hairpin too fast...I miraculously slid out the rear and slid over a traffic island while missing a sign post on the island and a parked ve ss sportswagon by inches...
Took the car to mt dandenong this Arvo...great place to put the car thru its paces!
Havent really felt any different comfort wise...I want to try the max setting on the front bars!!
Edited by ironpaw
Told ya :thumbsup:
BTW, all that "Corner Devouring" was obviously done on your private road; don't want people getting silly ideas now...:ph34r:
Glad you're enjoying them. :cheers:
Of course...I was strictly following the speed limit...just didn't brake enough :whistling:
Australia Post has let me down, and they STILL haven't arrived! :rant:
Hopefully they'll be waiting for me when I get back from Melbourne Thursday night. Serves me right for being optimistic with Australia Post...
Fitting them Saturday hopefully, going to follow Jules' suggestion of hard front and medium rear if I can work them out.
Couple of questions...
  1. Do they come with instructions on fitting/setup?
  2. Is the filing issue Scotty found only applicable if you fit them on a hoist/with the wheels suspended in the air?
No good mate, hopefully very soon!
I didn't open them up to check, but I believe they do come with fitting instructions.
I think it might be a good idea to slip the collar into position and check for clearance either way; saves removing them later if there's an issue.
If Scotty reads this; did you take a pic of where you were getting contact, or where you filed the collars for clearance?
I understand where you're talking about; but it might be good to illustrate for the others as my bars being a different diameter, don't have this issue.
If so could you please post them up?
Cheers, Dale.
Edited by Daleo
Yeah I no Dale, all good! Australia Post can just be slack sometimes, esp in my area!
I got the impression reading other people's posts that if you put the car up in the air with the wheels suspended, you'd get the clearance issue. If you put the car up with the wheels supported you'd be all good. Just wanted to check this before I gave it a bash.
It will hit either way, and im not removing all those tray screws and the bar again. lol.
Before you put the links on, just test the travel of the bar and you will see what I mean. File the upper clamp a little, both sides of the flat section and it will allow more travel.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
