Have you thought about Soda Blasting? I've had the paint blasted off some plastic grill parts and it looks great. I've seen it strip the ink off a coke can and the can was fine. I'll post some photos when I get home later to show you the results. I'll also find the name of the bloke that did it for me.
https://www.sau.com.au/forums/topic/357458-acid-bathing/#findComment-5714641
cheers , yes I was considering soda blasting there's a guy in carrum downs does it..
But I ended up going to paint mobile in dandy , he recomended some industrial paint stripper and it worked a treat..
I guess the stripper I was using just wasn't toxic enough to strip powdercoat :)
https://www.sau.com.au/forums/topic/357458-acid-bathing/#findComment-5714729
There's paint stripper and there's paint stripper. The former being a clear, glue looking stuff that seems to just fade paint after half an hour. The latter closely resembling lava in both appearance and touch that seems to make shit bubble and peel after 5 minutes. Thick gloves = necessity lol.
https://www.sau.com.au/forums/topic/357458-acid-bathing/#findComment-5716239
yeah thats the stuff, thick brown goo the can sizzles when u shake it..
I tried 3m spray stripper. 20$ for 2 cans did nothing
some green stuff from bunnings 40$ a litre was a little better but still no good.
25$ for half a litre of the good stuff from paint supplies store, i used half a tin and job done.
https://www.sau.com.au/forums/topic/357458-acid-bathing/#findComment-5717705
Yeah, you paint the stuff on with a paintbrush :)
You had any splash on your skin? Instant BURN.
The one the smells like ammonia?
We used to put a drop on our palms and see who could hold it out the longest...
but i've always thought they wouldn't work on powdercoating because its like baked on plastic.
https://www.sau.com.au/forums/topic/357458-acid-bathing/#findComment-5719110
No, the one that you smell and it burns your nose just because of the fumes lol. There's no way you could put this one on your palm and see who can hold it there the longest - it starts burning instantly and leaves something of a nasty chemical burn after 5-10 seconds.
https://www.sau.com.au/forums/topic/357458-acid-bathing/#findComment-5719487
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
