hi all.
well after botching my headlights. they dont seem to be sealing very well and condensating.
Im looking at getting some new headlights :)
what aftermarket ones are out there in availability?
Ive seen a few on IM with halo's at $1000 for the pair.
My only real need is they NEED to have a black background.. halos would be nice lol.
what do you all think.
just trying to weigh up the difference in cost of having these repaired - or get new ones.
https://www.sau.com.au/forums/topic/357478-m35-after-market-headlights/
hi all.
Most of the IM ones are an exchange deal.
Maybe time for a strip, scrupulous clean & reseal with Sikaflex?
The others seemed to manage it, maybe they have some tips?
Could be something simple...
just pull them out again... heat and split em.. and use some of the glassylite stuff to fix the clear-ness.. and sikaflex/gasket silicone them back together.. you didnt ruin your inside did you??, its just not sealing together properly right??
yes its a bitch of a job but will save you $$$ instead of new/secondhand lights.
anyway thats what i would do.. so far mine arent leaking.. but thats why i did mine to begin with, one was leaking and there was a spider living in there!!
hi all.
Got a link or pics keen to see what your on about
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
