hi all.
well after botching my headlights. they dont seem to be sealing very well and condensating.
Im looking at getting some new headlights :)
what aftermarket ones are out there in availability?
Ive seen a few on IM with halo's at $1000 for the pair.
My only real need is they NEED to have a black background.. halos would be nice lol.
what do you all think.
just trying to weigh up the difference in cost of having these repaired - or get new ones.
https://www.sau.com.au/forums/topic/357478-m35-after-market-headlights/
hi all.
Most of the IM ones are an exchange deal.
Maybe time for a strip, scrupulous clean & reseal with Sikaflex?
The others seemed to manage it, maybe they have some tips?
Could be something simple...
just pull them out again... heat and split em.. and use some of the glassylite stuff to fix the clear-ness.. and sikaflex/gasket silicone them back together.. you didnt ruin your inside did you??, its just not sealing together properly right??
yes its a bitch of a job but will save you $$$ instead of new/secondhand lights.
anyway thats what i would do.. so far mine arent leaking.. but thats why i did mine to begin with, one was leaking and there was a spider living in there!!
hi all.
Got a link or pics keen to see what your on about
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
