yeah just a normal 1jz not a VVTI
look forward to attending a few events this year,
We were following a silver stock looking R33 4 door with a cannon exhaust this morning going past narangba station,
we were in a white navara with yellow light on the roof so you probably never noticed us
I think it turned down torrens road at petrie
  On 14/04/2011 at 10:10 PM, FineLine said:
Hey you Northfolk, As of last night we now have a new executive to steer the club over the next 12 months.
We are planing a major upturn in events ans would like as many of you as possible to join in the fun.
We will be doing 4 major cruises a year and one of these will be in your direction. The club would like to hook up with you guys and then move on to the sunny coast and do the same with the skyline fraternity there.
Our first major cruise will be a western swing taking in the flood hit araeas between brisbane and toowoomba where we hope to hook up with as many liners as we can.
The northern loop will be the next mjor cruise after that.
Let us know if you are interested and keen in becoming more involved with an active club.
Cheers, your new pres.
:thumbsup: for sure
  On 14/04/2011 at 6:09 AM, RandomHero83 said:
Let me know when your open for business. my dash is doing some odd shit at the moment, I either need a auto sparky or a exorcist.
Will do for sure mate. As soon as I know, which I should know next week, i'll let you know.
Cheers guys for the support. Hope I get to work on some/all of your cars, as i would like to make this business the go to place in Morayfield and beyond.
116 any chances of a house visit. I have a 300zx that has no spark and the last guy did the dodgyest job of wiring i have ever seen. PM me if you can with your hourly rate and we can set up a time.
  On 17/04/2011 at 9:07 PM, FineLine said:
Keep an eye on the events section peeps. Fun times posted up and more to come.
When I had my 33 I used to attend Club cruises but being on the northside we always had to drive a fair way to get in on the fun. The effort to include north liners will not go unnoticed or unappreciated
well I'll kick it off then:
every thursday night at Carsedline central - we have a northside meet. start at 730-8pm till when ever. there are coffee shops/nandos/pizza capers and all are willing to kick in a bit if the meet gets off the ground.
I'll be there at pizza capers this thurs at 730-8pm to start it.
do we have takers?
do we have takers?
im in...but where the hell is carseldine central?? carseldine sounds good to me. easy to get to. and all highway!!
*never mind...found it..lol will be there i recon.
Edited by boiracer
its on the corner of Beams Road and Gympie Road
heading out bound its on the left
inbound its on the right
it is at the last set of traffic lights before the Bruce Highway starts
if your retarded the 1st exit isnt far up the road so a U turn is easy
Maybe able to swing out and have a looky. Not a bad spot. Plenty of parking up and underground.
As for the Harry's meets, the cops aren't as bad as they were. Been their plenty of times and they are a good bunch of guys. Last time I was their a 32 rocked up with straight through exhaust, 1 headlight working and slamed on it's nuts. A copper a guided him into the park and said nice ride. I kid you not. I spoke to him about there presents there and he basically said they were just to keep things under control and stop the dickheads. You still get some dickheads, but thats most places you go. You'd be very suprised how they turn a blind eye to the cars that rock up their. Another one, this guy had a Merc pretty much on bump stops and the copper goes, didn't you have another 1 the other week or was that someone else. Couldn't belive what I heard.
The coppers down there from what I hear are pretty good, However they did turn up just after we left because people forgot how to use a sidewalk and also how to exit a driveway without leaving rubber flavored momento's behind
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
