Just a rock bog stock 40th anniversary midnight purple 33 Col. Even has Auto, Knockyaselves out coppas. :thumbsup:
Your wheels are more than 1.5 inches wider than stock and are more than one inch larger in diameter than stock...there is your ticket right there if they were so inclined :P
sorry Noel, i was referring to my car... :P
although saying that, i never go a ticket in any of my skylines or even the SS... But ive had one in the Lexus :(
im still driving Japanese, just a different type these days...
our whole garage is Japanese actually right down to the bikes...
[/quoteI'll take my chances. the rolling diameter is actually spot on the allowable but the width is 1/2 inch over.
I wont be there long as i gotta grab my bro from the airport at around 8:30-9pm anyways. so BNR is out of the question for me anyways.
well i'll be fine too.....bog standard white R33...right down to the wheels that cant be seen unless your right next to it :)
saw a MNP one when i bought mine...40th anniversary. some 17inch mags. factory sunroof, think it was manual. looked schmick...but was more than 5 grand more than i payed for mine.....tooo much i says
seeyas all there!!
FYI : there is a meet of some decsription happening on monday 25th at 7pm. not sure who but pete tells me he's been asked to supply food.
may be worth a look.
Had a good time catching up with fineline, chris, ash and boiracer. No police attention just a good feed and a chat about some of the exciting events comming up in the next month or so.
Yeah NS.com are having a meet there on that date.
I will probably drive over and have a squizz. depends on how many people (or idiots) turn up.
hopefully they called the carseldine police station to tell them they were doing it. NS has a fairly big fan base.
seems like it very well organized. but if too many fools show up the cops will shut it down anyways.
having said that there will be alot of nice cars there and a night time Nebo run could be nice. just not sure if i can be bothered yet :)
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
