I'll be down thursday night i'll see if I can drag ash along depends on how much work he has on.
My plans have been defeated by a network diagram I have to finish. I won't be able to make it down tonight.
bugger,
well bodo and myself shot the sh1t and ate pizza.
debated about meeting up with the western guys but at 855pm we both decided to go home.
come on guys ...
if its a date issue tell me - I'll move to a sat night..
we should have gone to meet them. i got onto the highway to head home and got stuck in a traffic jam for the next 15 mins...grrr. they were moving big concrete beams, with police escort and all. my timing was perfect of coarse, right as they were bringing it onto the highway :(
twas a good bit of chatting, didnt even notice how fast the time went. look forward to next week.
next time im def keen to head over and see the others if our turnout is small. just need to head that way a bit earlier than 9pm
*pizza was cheesey
Edited by boiracer
how did you tell it was me?? everyone has a boring white R33 :P
i was just off grabbing some Woodies to acoumpany my Master Noodle......Mmmmm master noodle
I saw the number plate then you behind the wheel.
Ill have to skip training next thursday night and pop down,
Need to see what the G O is with installing a headunit and what bits ill need so Mr Rogers you might be the man to see!
our skyline is nothing special except the stupid air purifier that squeeks in the back parcel shelf!
Just a quick one guys. As of Monday we should be trading fully. We were opened this week but was very hard to operate since everything is spread arsehole to breakfast. This saturday we are spending yet another long day and night setting things up ready for monday. I've spoken to Peter about maybe a possible meet and gret at the shop and so far all good. Might organise something in a couple of weeks.
ive seen alot of activity in those back shops on my way to and from training , saw the RPM sign tonight
Yeah man. I worked out that in 9 days I done 200hrs and had 45hrs sleepy time. Still trying to recover properly lol. The body doesn't know what it's suppose to do anymore.
Is there some kind of meet on over at redcliffe I am unaware of? there was about 7 skylines and a couple of other imports heading over there today when I was heading back from football
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
