Well mate, if you like, we can do a dodgy, I pretty much have 2 complete piping kits for a gtir, we can always look at cutting them to fit with a shit load of silicon hose and clamps and make "custom made" pipe for it, plus I believe we could mock up some brackets of our own
Thats just asking for trouble, "custom Piping usually ends in leaks and pressure drop due to less than optimal pipe length and bends.
so is it carseldine this week?
Not sure what does everyone want to do? Me I want to play Gears 3 but I have to wait till thursday so I can co-op that shit.
i'm easy, as i pretty much in between both morayfield and carsaldine.
as for the customer pipe, this was basically saying that, if bodo really absolutely wanted to have a FMIC installed with little to no money, i have a FMIC plus pipe that we could cut and patch with hoses, this is by far not the best thing, as like you said would end up in leaks, but would be possible, as bodo would only need to get the hoses and clamps, i can supply the FMIC and pipe work, but in the end it is up to bodo as what he wants, these ideas are purely ideas and quite possibly bad ones, but ideas none the less.
Custom pipping may not be all it's worked up to be, specially if you are joining several pieces (silicone joitns cost). Might as well buy monsta pipping, or search ebay for the right length etc.
FMIC Ordered, hopefully here end of next week!
Anyone keen to make the meet weds/thursday? either of those days is fine this week, but coming weeks i will have to push thursdays (the mises)
im up for capers castledine tonight. a bit of a drive instead of just hanging around moronfield here. hopefullly chris can join us
im aware that doing a bodgy intercooler with far to many joins would be a dodgy. im just intrigued as too how well it can be made to fit. all those piping kits are aluminium arent they?? if so i have a welder that can fix that. :) i dont do bodgy, but if i can make something instead of buying it, i'll always take that option.....either because ima cheap skate or.....i dunno :whistling:. im sure the best possible intercooler piping length is, the shortest possible way. without going to many sharp bends. i'll see what Joe has there, and if its possible it will be a whole weekend project to piece together i think.
Well mate, I'll be going down to the folks not this weekend but the following, so I'll pick up everything I have, that's pipe hoses and cooler, I believe the pipes are not aluminum, I think there some sort or light steel with crome coating, basically the same as what I have on the line.
However, I might go down this weekend and pick them up as the boy is with the grandparents and I have a feeling I'll need to get him, I'll let you know mate, but I think I have enough pipe to do the kit for you
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
