those look nice there mate, been thinking about getting a new set of boots for the gear boot and hand break, but haven't been bothered as of yet, are they eBay special for like $20 odd plus like $5 for P/H?, if so, can you let me know how they go please
yeah they are, 20 bucks, and 9.90 postage from britania land, the leather is nice. everything fits well, even the rubber top in the gearstick boot. its made to replace the original exactly. i had to trim a little excess around the bottom of the gear boot, and the wire frame in the handbrake boot is a little to soft compared to the original, but hasnt been an issue yet (if it pops out ill add a few dabs of glue).
Mmmm car smells like leather
nice figures mate,
yeah it's sledgehammer like, on another note:
Those who are wanting to cruise down to QR as a group we are meeting at the southbound BP on the highway at 4:30am for a 4:45 leave time, This gives everyone 15 mins to grab some fuel a coffee and a feed.
Make that 4AM just to account for slow people and a quick hello.
been thinking a little lately, i have 2x 10" thermos i want to install into the skyrine, and i was wondering if this would be benificial or would it be better to just get like say a single 16" thermo
Thermo fans are only benificial if you have a shroud for them. There are some shrouds if my memory serves me correct on ebay that suit the standard rad. Control wise, I'm not a hugh fan of the thermo control units that use the probe in the top hose, you would be better off using a thermo switch sender mounted in a bit of stainless pipe in the top hose. If you have an aftermarket computer you can use it to trigger a relay.
happy laps were double as happy!!
track started getting wet again after we had breaky and they asked us to go out again and dry the track off for them (V8 Experience guys).
sry for leaving yas behind, i was in a hurry. Clint you and old mate (forgot his name already) make it thru ok?? i got to the christening about 3 mins late :P close enough for me :thumbsup:
Yeah I just took Joe up to Beams road and pointed him in the direction of the Highway. I saw ralph going back the other way what was that about?
Guys it was good to see you at Double Epic Super-Happy laps!:action-smiley-069:
Thanks for having us, I will finally after 5 years be filling out my membership form and getting that sorted Monday.
haha old mate!
ended up getting home and goin back to bed for 3 hours, 4am is far too early to be getting up..
had a good day though, would have been better if clint didnt steal my ride in Noel's 33!
BTW mate, didnt happen to run into any P plater Lancers on the way home did you ;)???
Edited by GTR_JOEY
haha old mate!
Funny you should mention P plater lancers, there was one acting the fool on the way home in the wet.
I stole that seat fair and square, I have been eyeing off a ride in the wheelchair since it was unveiled.
You'll just have to come up again when it's at lakeside then he can take ya for a real lap.
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
