I do remember at one stage considering putting GTR driveline into it.
Welding you say? I'm getting real good at it now, off again tonight to weld the support trailer. Only a couple weeks away now really.
just spent a few hours reading different threads on boost, those "people" need to really learn to spell full words for starters, then on top of that, stop stupid threads, but hey, it's all good for a laugh
Boost is where all the special people live, Special in a helmet and crayons kind of way.
Fckn lol yeah.
I may need someone's assistance with diagnostics on my 33 sometime, other than the turbo missing ;) I have a miss below about 3500rpm and think some douche off boost put turbo injectors into an rb25 de.... And all the breather piping for the rocker cover just looks wrong....
    • Man, you guys are like an all knowing encyclopedia.. how do you guys know how to fix everything?? but thanks. i will try to trace this wiring today. What is this globe thing you are referring too? Globe Power Supply? Are you referring to the light bulb?
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
