FYI Boost cruising meets are gay, It's more bogan than a Commodore packed full of vb drinking mullet rocking Cabbo natives listening to AC/DC while yelling out the window about how they can cut "Heaps sic skids" in there mum's hand me down VN.
Take it you went on one
On another note, is there anyone from the northside going to motokahna this weekend?, if so can you please let me know as I was thinking of a small cruise down to it
No, was going past Autobarn here and spotted the even they were on about over at Boost Cruising took one look (from the lights above the shop) and kept going
Well I have never been on a cruise with boost cruising, and never plan on going, I feel there would be too much cop attention, as well as too many dickheads (sorry for the bad language)
Thought u were going inside, don't turn to the darkside now clint..
Who wants to follow some p platers around in cars with holes threwout to make it sound 'like boss' anyway :S
On a side note, anyone ever had experience with intercooler water sprays? to 'cool the cooler down'.
not me personally, but i know someone who did it to there N16 that they boosted, he used a washer bottle to hold the water and used the pump from the bottle to inject the water, as for the delivery system i think he got a high pressure nozzle to act like a injector, and had it just before the throttle body
i think it ended up spraying a very fine mist to cool the air
from what i remember reading back in the day on fullboost they used a pressure switch so it only turned on over X boost otherwise you would empty the container in 5 seconds...
the biggest issue was getting a fine enough mist using XYZ pump and XYZ nozzle so it doesn't just drench the cooler as that is TOO much water and ruins the cooling effect as the water just sits on it
There are two Item's one being a wiper like nozzle and bottle that spray the intercooler it'self or the water methanol mixture that injects into your intake, Neither are really worth spending money on until your making power.
I am looking into water / methanol injection at present to see if I can run it with my current config and steal another 100hp out of my car (with cams and exhaust cam gear)
Wouldn't bother dude with the water/meth setup. Don't like the setup they come with. Don't know if you remember, but that green 33 that was at work had one in it and the bottle leaked all the time. From what I could tell it was a brand new kit to that the owner installed. I have the C02 sprayer on my car and have not done any test to see if it makes any sort of a difference. As for the water sprayer idea, go to bunnings or a garden shop and buy yourself some irrigation nozzels, get some vac line, or buy a universal washer bottle kit from Repco and use the line and away you go.
I came 4th in the sq novice division of the MEASQ Contest down in Enogera tonight,
Blew 8 fuses in the amp (configured way wrong by installer) so that is being fixed tonight / tomorrow, On the plus side it made 135.6 DB on the in car DB meter before it blew the fuses.
Guy doing it said it should do 140 pretty easy once i fix the screw ups.
Damn eh, let me know how the CO2 goes when you get a chance to test it (with the amount of work you have on I will have blown and rebuilt my engine before you get a spare min to test it) I'll let the idea sit for a while and wait and see what actual results people are getting before I pursue the Idea or go another route.
Hahaha. Yeah...... I know. It will be happenning soon though once i sell the pulsar it'll be off the road and getting done.
Nice,
I may have need of your services to do some voltage testing on this sound system of mine, and check the earthing in the boot. I had a slight bit of alternator noise during the sound off 0 bit track.
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
    • These look like S13 wheels.  And Welcome!
