Outer Northside Aspley To Caboolture
RandomHero83
rebuild an old car yourself, that's sooo fulfilling.
on another note, im out for thursday. Maureen is gonna be gone all weekend and im gonna spend the night with her.
and on that point an thinking about doing a bit of a LAN downstairs in my house over the weekend :)
well to be honest, i'm doing some work experiences at a panel beater that restores old minis, and am currently restoring one, as for lan, i would if my computer hadn't have been totally F**KED over by my uncle, need to spend at least a grand on it to get it back to the way it was, so is on the to do list
Hey guys,
Just wondering if any of you know a good place around the Bribie Island & Caboolture area to get a body kit fitted and painted.Got a kit from DMD the other day and also have a bit of wheel arch rust to get fixed at the time time.
Looking to get both done at the same time. Any help greatly appreciated
Thanks in advance, Scotty !
all good man, LAN isnt happening anyways, due to the SAU cruise being on Saturday (which i previously thought was on sunday).
having drinks and video games at home just tomorrow arvo/night instead if anyones keen.
Hey guys,
no idea to be honest man, the only panel shop ive ever had anything to do with doesn't exists anymore.
What games are you playing at this LAN?
Hey guys,
Hey mate,
I know a bloke who might fit and paint the kit and would be able to fix the rust spots, the only catch is that he is in northgate, but I know you would be able to get it booked in fairly early
did you buy your minecraft Bodo?
yes indeed, been a few years now, got it while it was still alpha. with the promise of free updates forever!! lol think it was about $15....havent played it much in the last few months.
if you get into it, you should join Ben's server. we got some serious building going on therre
What other Mods do you have?
Full 3" Exhaust
FMIC
Vipec ECU
Boost Controller
Think thats it
Ive got some 740cc injectors at home to put in with the turbo, hoping for over 260rwkw
Full 3" Exhaust
FMIC
Vipec ECU
Boost Controller
Think thats it
I brought a SS1PU for my 34, I am making about that power figure now mine has:
600cc injectors
z32 afm
full 3" exhaust
hypergear ss1pu
Hybrid FMIC
Apexi Power FC
Gizmo boost controller.
tuned on 17 psi
The big thing to keep in mind is that the stock head gasket can only take so much before it will crap out hence the low boost on mine, it came with the actuator set for 21 psi.
600cc injectors
z32 afm
full 3" exhaust
hypergear ss1pu
Hybrid FMIC
Apexi Power FC
tuned on 17 psi
I was going to get the SS1PU originally, just changed my mind at the last minute to the SS2. Whats your thoughts about going to a highmonted setup. Im undecided whether to stick with the low mount of shell out and get a highmount manifold.
Are you rolling stock plenum?
Yeah still rolling stock plenum atm, looking at grabbing a front facing, water meth and Cam's next
    • Great to know! The guys from The Skyline Shed are going to sort it out and send what I ordered anyway. Turns out their supplier sent them the wrong stock.  But it's good to know I "can" put this in if needed
    • You do not need an LSD oil in any stock (non-GTR) diff, even if it is an "LSD". This because none of the (non-GTR) LSDs are clutch/friction type LSDs. Either viscous or helical - neither of which require an LSD oil.
    • Hi everyone, I bought the Redline diff oil and the seller has sent me Redline 75W90NS even though that’s not what’s pictured.  I’ve already booked a hoist to go and change my diff tomorrow but I’m not sure if the NS is ok for the rear diff in a R34 GTT I think the NS does not have any slip modifiers so would that be an issue?    thanks in advance
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
