No horsepowers intended.
i was going to get a full set of Superpro suspension and cradle bushes. But I just got back from Fulcrum (because I missed the tech night there) and other than a loose top bolt on the drivers side rear strut top, all my bushes are good.....they were quite surprised, and I can spend $580 elsewhere :)
So now that my plan has changed. I'm not sure what exactly to get, but this is my list so far.
Hicas locking bar
Center caps for wheels
Wrap or plastidip center console inside.
New video card and mousepad (already paid for and installed)
new front rotors and pads...finally get rid of that annoying and increasingly ear piercing squeak.
New front speakers.
Brake fluids replaced and new ABS module (if I can find one for a reasonable price)
Booze for origin tonight
Jim Richards dinner tomorrow night.
Get my exhaust lifted up higher under the car.
and If cash permits Either build a new computer (only need CPU, MoBo, RAM, and cooler) or swaybars.
Hicas locking bar
New front speakers.
None of this involves an ECU and tune...I think you have missed something.
Hicas locking bar
Bodo, if your considering a hicas lock bar. This might be worth a look... A full eliminator kit, i got this on my car and find is absolutely awesome. Car feels s much more connected to the road etc. But i have not driven a car with Lock Bar only so not sure of comparison. I was pushed towards this kit instead of the bar only
http://shop.cartel-aus.com/Total-HICAS-eliminator-kit-for-Nissan-dw015.htm?categoryId=-1
Sweet! bright orange, can you see it under the car at all?
this is the one I was going to get. As it saved having to replace the hicas tierod ends.
http://www.ebay.com.au/itm/Total-HICAS-Eliminator-Kit-for-Nissan-Silvia-S13-S14-S15-Skyline-R32-R33-R34-/181145112508?pt=AU_Car_Parts_Accessories&hash=item2a2d170fbc
But seeing as everything is fine under there, I'm just gonna stick with getting the regular old locking bar. as there is a big price difference.
Yes, orange is very visible under the car
:/ I'd avoid then unless cop attention is what one is chasing. Apparently new laws coming out and they might be trying to get us for lots more srupid little things.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
