I dont, not sure about the other guys up here. Where abouts on Bribie have you moved to? I work at PAcific Harbour Golf Club but im in Woorim regularly and live just off the island
I'm just off the island too, ningi is where i'm living. Been driving a bright green r32 with a bodykit around, looks semi okay, but it's only a 20det with a vg turbo on it.
Haven't seen your skyline around yet, must be a bit of a handfull to drive.
you live around the corner from me i think. Ive seen a green kitted 32 up the road a fair bit. Im in Sandstone Lakes, Water Gum Cres to be exact. A bloke over the road from me was pulling a 32 off a car trailer the other night also.
My Skyline doesnt see much road time over the past few months. But when it does it can be a handful depending on how heavy your right foot is at the time
Yeah, you are just around the corner. Im on sandstone blvd, have to catch up sometime. The 32 (not mine by the way) will be up for sale soon. We're going to build a drift 31, i've still got so many parts in nz so should be reasonably cheap!!
Small small world. Will definitely have to catch up sometime
Check this out.. This is what was happening on my dyno in the weekend, gutted i wasn't there.
http://m.youtube.com/watch?v=4_G6q89QHgM
Need to buy another one over here, need something to do while i'm on r and r!!
Yeah, i drove it the other day (not my car by the way i have two in nz) I think the new mazda would eat it! it's a bit of a joke, looks good, but thats it.
Going to take it for a drive now actually, go get some pizza!!
  • 4 weeks later...
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
