Turns out my Fuel pump needs to be upgraded again :-(. Car made 405rwhp on 20psi with a blend of 70% pump fuel and 30% E85. Impressive numbers i guess but the fuel pump was maxed out. Upgrading to a 400L Walbro for now till i can save some $$ for a full external setup. Also injuectors will be next on the list as they are reaching their limits
What pump was in it currently?
I went a bosch 044 in tank mount and 660cc injectors but I will not be going e85 as it is a pain in the ass to get here.
Walbro 255 from memory. Going to 400 for now as a quick fix till i can afford a full setup. I also have 740CC Nizmo Injectors. These will also be reaching their limits once the full E85 tune is done. May look at some 1000's.
E85 just seems to put a lot more strain on these parts compared to going with a bigger turbo and hitting these HP numbers on Pump98.
Hopefully it will see closer to the 430 number by the end. Which is a lot more than i expected
Ive got a maroon R32 GTST. I work at Grand Prix Mazda at Aspley haha, Hope to see yous all around :)
Hey mate, welcome! Feel free to come to our dinner this week and meet some of the club members and share some food and beer. http://www.skylinesaustralia.com/forums/topic/425064-dinner-and-chat-prt-16/
SAU drag day is happening in July.
All you horsepower junkies need to come join us!!
June mate...
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
