 so they sell Maccas?
I assumed the series 1 didnt have VCT at all.  series 1.5 and 2 have it on the exhaust side, and the 34 NEO has both intake and exhaust....or so I thought.
Worse than maccas!
Is on the intake cam only in all forms of rb25
Worse than maccas!
nothing is worse than maccas.
hold on what? so the CAS is on the exhaust side...makes sense I guess seeing as that is the exhaust side of the engine
Man i gotta stop reading the internets
If you believe everything on the internet you're gonna have a bad time.
1 Skid, and general wear, It is bald as all buggery on the inside, heaps of meat on the outer edge, Unless the cops look under it she looks like it is good. New one next payday.
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
    • Interesting, I've heard complete opposite on my end. Bit of a lottery I guess.
