Oh yeah i'll bring the new toy, we meeting at Southbound BP at 7:15 ish again or no?
Chris if you read this prior to tomorrow night can you please bring the R32 window switch setup you have I keep forgetting to remind you.
We may be a little bit later than 7:30 like 7:45 as missus is doing personal training till 7:00 or so apparently even tho she knows wednesday nights are skyline night.
lol, so you wont be able to make it to the BP even if we do group up there?? i'll message ash tomorrow arvo and if hes coming we can congregate there on the way out. Ralf normally heads here first anyways, and ash is around the corner.
so i think we can give the BP's a miss
sooo im confused, we meeting at the bp? anyways ill be heading to boi racer's place b4 we head over there so we can figure ash out if he doesnt get lazy again. O and clint depending on how long we are out if i could grab some bleach off you would be great... watched some recently and now i really wanna keep watching it :D
So After today I have the following goodies comming for the car:
FMIC
Turbo to CAT 3" exhaust (currently CAT back thanks for mentioning that it is quiet outside the car bodo)
Carbon Fibre GT Wing (I can't help myself)
Yellow Jacket Coil Packs
Power FC (picking it up on the weekend)
Suspension (being replaced under warranty if they offer a partial payment for it I will do BC Racing V1 Coilovers )
Alarm and Gizmo MS2 boost controller
May need to do the clutch as well. that leaves me with a tune to go then.
i should know what a quiet car sounds like after all.... :nyaanyaa:
let me know if you do the coilovers yourself. been thinking of doing the same on mine. i figure it shouldn't be too hard, then get it professionally aligned etc
Was out helping (mostly watching) steve put his new engine in. Tomorrow the new wing goes on and then it's back to work where all my goodies will be delivered this week hopefully. In other news my Power FC already has a tune for 200rwkw's with the mods I will have so it will bolt up and off to the tuners it goes.
dam man :( that sucks
Happy laps was freaking sweet!!! lakeside is my new fav place in the world. we should do wed night meetings there....if only. i had the biggest grin on my face afterwards, ahhh yeah!!!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
