it could be any of the rubbers under the front, mine for example im pretty sure are the sway bar rubbers.
as for parts, no idea yet either, havent had to co any of this stuff either. but i'd say give bursons etc a ring first. and let us know :thumbsup:
are ball joints DIY'able ?? where is best place to aquire them?? bursons/repco or ebay or other??
I am used to regular aussie cars(all my previous cars were ford fairlanes.. ZL(XF shape), NA (EA shape), AU.. where parts are easy as pie to get from the usual sources
all this import part shenanigans is new to me haha
if its suspension bit - fulcrum stafford. PM KRCHER (carl - kiwi with the black R33)
he will probably be able to help.
failing that I can if you can provide a build plate and what you think you need.
An update on my 33, not as good as clint tho :P
Installed FMIC (HDI HYBRID) few months ago
Recently installed digital calibre guage + turbosmart boost tee (clint wired all the vacuum leaks out for me, still yet to clean up)
I have the 3" cat back exhaust, so not im waiting till next week (hopefully) then i will order my front dump pipe and catback, then get it installed either threw people i know or threw a shop.
but due to an unexpected suprise, i will be waiting to get my tune (ill pester the fiance) and try to get it done. then for now, thatd be it for stage 1.
to come, i will be looking at getting a 90m forward intake plenum with a 90m throttle body, then the respray (or which ever comes first!)
sorry i havent been active at the meets, but im keen to start it up again!
~ash
all good man, non of us have.
i think we leave it all for the new year. i dont know about you guys, but i got alot on at the end of any year.
update on my car, gonna wash it today.....
other than that, gonna go see chris in the new year for a fandangle everything alarm. i guess all the liners disappearing this year has scared me into it enough.
Turbo has arrived :)
car isn't booked in until jan 3rd :(
Drum kit now sounds pro after a new skin setup compliments of Guitar exchange's drum shop and Aaron's pro skills.
Umm yeah apart from that nothing else but waiting now
G'day All,
First post and just moved to Brissy 3 weeks ago.
I just bought a R32 GTST pick it up on Thursday (Hopefully)
I'm on the north side too in Murrumba Downs. I am curious too since I am new to the area if anyone could point me to a decent place to get an alarm fitted (Not sure if it has one already yet but I want something a little overkill after reading about all the skylines going missing) or I am sure my german shepard would be happy living in it :)
Plus what tuner shop would people recommend up this way?
Cheers
Chris
G'day All,
Cheers
Chris
Hi Christian welcome to Brisbane, Murrumba is a good place to live.
The tuning shop I am using is RPM in Morayfield, Peter Roma does an excellent job on tuning my car and is about to do even more.
What has been done to your 32 already or are you starting with a fresh base?
Alarm you can't go past Chris Rogers in this thread somewhere
+1 Chris is the alarm pro.
It has the basics,
FMIC
Dump pipe & Exhaust
Pod Filter
HD Clutch *Can't remember the spec at the moment*
Then just the typical turbo timer etc...
I am just wondering what should be a couple of the first mods to do to it. First skyline but my brother in law had a R33 with similar mods and a few extras like PowerFC and a few other bits.
Last car was a XR6 Turbo back over in Perth really nice good car but I've always loved Skylines.
Cheers.
Chris
It has the basics,
FMIC
Dump pipe & Exhaust
Pod Filter
Cheers.
Chris
Coil pack's then a Nistune unless you want to go with an after market ECU ( Power FC)
holidays..........ill get those soon!!! dammit!
finally broke something on my car recently. not sure when exactly....tryed to squirt the front window...but with no luck.
i assume its just the motor, as the rear one works fine.
what oil you guys running in your cars?? Motul Turbolite is getting real hard to find locally...despite being told they are still stocking it. and ralfs cars oil pressure drop since pouring Penrite into it. seems like all theyre oils are just plain average :(
Just a quick update, picked up the R32 today.
Look forward to meeting a few of the peoples up this way.
Couple of little things I've already spotted is right rear shock is a little shot quite a bit of wheel rub on the guard with a person in the back and passenger seat hardly any with only someone in the passenger and none with just me in it. Other than that it handles very well, was coming onto the Gateway Motorway just driving normally not even had the car for 4 hours and the police zoomed across 2 lanes and screamed up behind me was pretty odd wasn't speeding or doing anything stupid at all.
Only other thing at the moment is under boost if I stomped it it kind of surges and there is a little bit of a pop from the exhaust when I take the foot off can tell its running rather rich it has a petrol smell floating about, obviously needs a tune. So any good advice on tune shop or getting stuff (not too expensive) prior to a tune would be good.
Will actually have a full list of what has been done to it once I've properly done the "just got home" inspection but the turbo back exhaust is HKS as well as the FMIC its a rather straight / tidy R32 needs some work on the paint here and there though and can tell its been nicely looked after.
Just thought I would drop a line and let everyone know :)
Cheers,
Chris
Cheers,
Chris
:thumbsup:
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
