You need a car that runs first troy :P
thursdays might be a better day for some now, i will attend every day for 2 weeks, then i need to skip b/c of work.. what kind of meet, the usual?
is anybody elses channel 7 and some of channel 10 gone bad since all the rain??
mine keeps dropping out or just goin real bad for a while then comes good and repeat..
thinking maybe some water got into teh cabling but only affecting channel 7 and somtimes channel 10 makes it wierd??
my antenna is not even 1 year old so it can't be that
well mate, as my job description is broadcast technician, and i work in the field, the problem you seem to be getting has nothing to do with your end, it is actually the broadcast tower itself, now without seeing in person both your end and the broadcast site, i couldn't be much more help, the best answer i could give you would be to wait till tomorrow and see how things go, and to be honest, it is a little late at night
sorry i couldn't be of more help
Yeah the other TVs work perfect(gets the missus off the loungeroom tv so I can watch movies or play Playstation lol. But that's not the point...
So you think it might be the cable to the socket??
Quite possible man, plug the working tv into tht spot and if kt works the charm its the tv, if it doesnt theres something wrong with that line alone, also swap the antenna cords as well(try it all bar the hammer!$
So...
This Weds or Thursday coming seems like a good time to do a meet, the question is where?
Possibly Carsedline (a good drive would be fun) and the Morayfield'ish liners can meet at the usual spot on the highway @ the BPs?
For a minute there I thought i'd clicked on tellytroubles.com but no, its SAU :)
Well, we're more than able to attend the weekly meet n have a feed, but someone... (Ash?) may have to provide a back seat and door to door service... Its coming along, but very slowly. Other jobs keep jumping in front of it.
Found a 25DET +ecu + running gear for $1500....all I need now is an LSD and a free weekend...
and some cash.
*passes bowl around*
Crapstix. Worth a shot. :(
Start work tomorrow, so good to be employed again, nearly 3 months on the sidelines sucked ass. Hope to catch ya's on the weekly.
Ash! Msg me n let me know wats going on ;)
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
