anyone recommend a decent place to get a fiberglass front bar fitted and maybe painted ( if its not going to cost a arm and leg as its a non standard colour and thought just getting it made up in spray cans) locally.
Just curious whats an average price to get one fitted if you have done it also
Trust me don't go the cans route, There are some people on the forums that have done this and I have seen the end result of the work... Take it to a pro and get them to work the voodoo. Best bet would be to shop around what area are you in?
agreed^^^
So whos coming to happy laps? at QR this time for a sunday breakfast. so its gonna be an early morning drive.
oh and i bought this yesterday :)http://www.ebay.com.au/itm/261057060347?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2648 but wont be here and done before the weekend. so next week my fulli sic Zorst should be sorted from turbo back
I'm from morayfield, have any of you guys used a body shop around the area? Or anyone that wants a cashie to just fit the bar?
I didn't really want to go the pressure pack can route, but i needed a 30cm strip on my a pillar repainted completely and got quoted $1300 just for that a bit, and a touch up on the door handle from a place in caloundra, that's why i was thinking the can theory. I assume it was so expensive due to the work needed to blend it all to the same colour.
I will end up getting it sprayed professionally though.
sorry man, i got no suggestions :( always done all and any bodywork myself (has been a long time)
yeah colour matching can be a real pain...and your biggest issue.
so whos keen for a meet/drive tomorrow night??
i'll have to get back to everyone about tomorrow night, as my cousin has asked me out to a opening to some club in brisbane
sounds like something i may have been interested in 10 years ago :P
I'd be keen for a meet up.
good to hear. i think we go Carseldine way for some tasty Pizza, then off to see the westies if we dont get much love on the northside :)
I have a surprise on call stint, so no going out for me. maybe next week now....wait wait next week is batman so the week after maybe.
Edited by RandomHero83
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
