Hey bodo, when ever ya free dude I got that knobby. Just waiting for the major modification! Lemme know!
Oh got the reservoir too. Thanks jdmspares for sending me a dirty and gunk reservoir tank. Beer buying from u again.....
Sorry been real busy...and totally buggered. didnt reply to your message either :(
should be right to do it some time this week, as for the lights. cant remember exactly which ones they are. ill find the packaging and let you know.
Just got back from getting the wifes Beetle tinted. looks good. :woot:
No worries dude, I'm on arvos this week so maybe catchup on the weekend. I've got a cold ATM so don't wanna give it to anyone else.
My sticker mistake has been fixed thanks to Troy, cuttin is back and doing one more cost and wallah. She's new!
Got my car back yesterday... Crank Angle Sensor was rooted as well so got it upgraded and new tune. Dyno attached
Mods are
R33 GTST S2
Stock motor
FMIC
Spitfires
Nismo 740cc
Walbro fuel pump
Vipec ECU
GT3076 [Low mounted & Internally Gated]
3" Exhaust with Hi-Flow Cat
4" Intake pipe
Still seems a low figure. Do you guys agree?
Edited by SCR48
That looks ok IMO, how much boost are you running? May not b a huge thing but if u dif the pump did u do the regulator aswell? I know Clint did both and he runs close beside a high flow.
Still a big improvement though!
I was going to go with a highmount setup, but the costs and cons of doing it isnt worth the money nor the power you make, which isnt a hell of a lot.
There are so many more options to go than that, but thats just me :P i would probably look at going forged if you want a beastly power with the 25, now thats worth some dosh :D
Bodo, lemme know if your free sometime before sunday this weekend? ill bug ya for the gear knob, otherwise tee it up for next weekend
Running 18psi.... Think I'll look into upgrading exhaust to 3.5" and save for highmount setup
Lot more money and not better result. is that 3076 in a .82 internally gated rear housing?
Having said that its an out come of a package instead of a turbocharger alone. As a bolton option it isn't unreasonable, and rarely any one makes their desired output in the first go. Either way, the most your are likely to see on paper with current setup is roughly 280rwkws. For trouble shooting I would drop the exhaust, try a different pod filter, and a different cooler. Some of the small alterations do make a big gain.
Ultimately a proper high mount manifold and external gate definitly helps with top end power.
Sometimes northing ever goes right does it!... driving car around last day or so and seems once i get a little happy with the right foot it starts making a strange sound in boost over 4000rpm and engine light flicks on and off.... Looks like it back to the workshop it goes on Monday. Hopefully all will be fixed for powercruise on Thursday
its likely to be an occurance of high level knock. engine light doesnt come up unless knock level goes beyound 60 means danger. the sound you heard is probably detonation. i would take it straight back to the tuner for a check up.
does the engine light blink on then off?
Yep, exactly what it does.
its likely to be an occurance of high level knock. engine light does come up unless knock level goes beyound 60 means danger. the sound you heard is probably detonation. i would take it straight back to the tuner for a check up.
already booked in monday. hopefully it gets fixed
Welcome to the world of detonation unfortunately. Not bad power for the mods. If you do little changes, such as a larger exhaust or a different pod filter, it can alter the tune a little. A lot of people don't realise this. There would be nothing wrong with the size of the exhaust, there are plenty of cars producing big hp on 3" systems, so I wouldn't be worried about that. If you want to change pods, i'd do it now before it goes back, or give them it so they can fit it before they retune it.
It's got a new pod in the last few weeks, they just upgraded the CAS the other day and retuned it.... Maybe it's related to that...There's a thread in forced induction where someone is experiencing knock and believes its CAS related
Edited by SCR48
+1 to the exhaust. To many people think the exhaust is the answer when it isnt
Don't mind me just lurking around, I'm a North Sider not rocking a beasty Skyline yet.... but hopefully real soon just wanted to have a look and see what we got on the North Side :D
Edited by NFORSA
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
