Hey everybody, does anyone know the measurements to a stock radiator in a R34 GTT. I'm looking at upgrading to a PWR product, If anyone has already done this what were the benefits you saw, how long did it take and how much did it cost.
Cheers
https://www.sau.com.au/forums/topic/357537-from-stock-radiator-to-pwr/
Two bolts for shroud, two bolts for radiator top supports... bottom hose, flush coolant, remove top hose, remove radiator and replace.
Took me about 20 minutes to remove the old one and replace. Looks fat and will give you so much better cooling potential. Very worthwhile upgrade in my opinion.... next is silicone hoses and better clamps.
Also the radiator has nice strong alloy hose outlets, as opposed to crappy plastic ones that break in your hoses.
Thanks mate spoke to a guy called jamie at Natrad radiators in midvale said its top of the line in radiators, but also mentioned that if your at the lights it can creep up over half way on the thermostat, but as soon as you get going again it flys back down, do you think this is a huge problem or is it cause that the radiator is made out of aluminium. Also I'm gettin a Garrett GT30 turbo upgrade, bigger injectors and a airflow meter installed soon do you think that having the radiator put in will help keep everything cooler or be the same with a stock.
It will probably be the same as stock or better. Ebay aluminum radiators work a treat :) no problems with them so for a while.
Depends what you're using them for.
I had an ebay ally radiator and it used to heatsoak something horrid after half an hour on the hwy and temps would just steadily increase. It also couldn't handle a decent burnout on a 40deg day, would spit coolant everywhere.
Turfed it in favour of a stock 32GTR radiator and the difference was huge. Temps well under control, a good 2.5min burnout on a 40deg day would see no more than 105deg.
Also a FYI, temps WILL increase when stationary UNTIL hot enough to engage the clutch on the engine fan. If it gets TOO hot, the A/C fan will kick in.
Another FYI, you won't notice the needle on your factory temp gauge move until the temps are over 100deg.
  • 10 months later...
Nah not yet mate was gonna be the last of my engine mods, previous mods were tomei typeB camshafts, bigger rear housing on turbo, on top of other previous mods now running 324HP so pretty decent for everday car will post up when done and if increase in hp or better performance overall. Spoke to a guy a Natrad radiators a few times, so have a few other people on this site says there the shit, so i will have it done eventually.
Are you having overheating problems at the moment? Do you have an oil cooler?
I am running the stock radiator and clutch fan with 400rwhp and no overheating issues.. Got a bit hot on the AHG pan with then it was understandable considering the ambient temps.
An oil cooler would be of a lot greater assistance than going for a replacement radiator - unless it is faulty.
Good point on the oil cooler. I'm not sure about the OP but my radiator is visually rusted inside so I'll conduct another flush and replacement. I'm also considering a cross-flow radiator. Anyone have any experience with the PWR crossflow (or any other company)?
In all honesty mate spend your money on something else for your car.
My 32 is running a standard rad and after 5-6 laps of beating the piss out of it around barbs it is still only around about 115 deg.
IMO dont replace it unless it's broken
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
    • Stripped the tank down and gave it a good scrub. It came up really good! Not sure if I'll just put it back in like that or give it a blackening treatment (such as Bowdens The Black Box). That might give it a matte look so might just run it as is.
    • @MBS206 Ha ha, yeah ADHD is a daily battle to not get drawn in to doing things you want to do that you know you shouldn't do!  Every single time I walk into my shed I end up doing something I started the day having zero intention of doing! I keep mentioning the 1 step forward, 3 steps back scenario and I'm tipping people that are blessed with ADHD (yes, blessed) are the worst at that!
