Hi I'm a new manual driver, but my dad drove the car and he had the same problem. I just received my car that I had bought last week for the first time, it's a nissan skyline R34 25GT coupe with manual transmission. So this is what happens, gear 1 fine, rev it to 3000 rpm, change gear to gear 2, release the clutch, JERK, then smooth then rev it up to 3000 rpm again, change to gear 3, release clutch, JERK. Now I've experimented with this a little bit, when I slowly release the clutch, the jerking is quite minimized to an extent where sometimes there is no jerk. The jerk feels like it pulls you back for a split second, then you are running smooth again.
Any ideas to how I can smoothly / consistently change gears rapidly without this jerking problem? Or is it entirely about the transmission?
Help appreciated!
https://www.sau.com.au/forums/topic/357542-clutch-jerk-issue/
Help appreciated!
You and your father may not be used to the engage point of the clutch so you are letting it out quickly without having revs to match it. If the car has a factory clutch fitted, it should be quite smooth. If it has a button clutch (which it probably wouldn't) or if the flywheel was lightened, then maybe clutch related. Otherwise, I think maybe getting used to it a little more might help. Obviously it's hard to work out what you mean from a description online but if it keeps it up, take it somewhere so someone experienced can drive it and feel for themselves
Hi I'm a new manual driver[/b
This is your problem mate. You shouldn't try and slip it, that just makes it die sooner rather than later. Give it a week and you'll be driving it like a champ
Practice makes perfect.
Be confident, but not forceful with your gear changes.
Match the revs to the gear you're selecting, then quickly but smoothly release the clutch.
Learn where the catch point is, it does take a while.
If what you say is true and you're being pushed back into the seat (sudden acceleration) when you change gears you might be leaving your foot on the throttle a little bit when you've got the clutch in.
But again, practice, just find a nice loop of quiet road and cruise around until you get the hang of it!
You can slip a factory organic clutch, they are made to be slipped. But you shouldn't have to if you match the revs correctly. Remember to apply a little throttle to bring the revs back up for the next gear...they're obviously falling too far during gear change. You will get used to it anyway, as you'll start to learn what RPM you need to be at for the next gear to dis-engage the clutch smoothly.
Another possibility, if there is actually a problem with it, is the clutch pivot ball could be worn and causing the pressure plate to release in a non-smooth motion. More than likely the first scenario though, you just need to get used to it. Skylines aren't the friendliest of cars to learn manual in, particularly if it's turbo.
Stay VERY lightly on the accelerator when shifting and it will make a big difference. When my car is cold, my shifting is shit and I occasionally almost stall. Once I'm warm, its smooth sailing.
What is f**king annoying is bumpy roads and your foot goes TAP TAP TAP on the damn accelerator!
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
