  • Replies 72
Posted Images
fair enough.. so i want to change the headunit but my r34 is different to most.. what do i need to do just to change the head unit, most likely chuck out the stock tv thing and would you recommend anyone in melb ?
well this is what i did to mine, i just removed the headunit (radio bit but can be any bit of it u want) then unplug the back cables (takes some skill u gotta find this button and pull hard, you might break a finger nail in the process) find a headunit you like either online or at your local car audio shop (i got mine from autobarn which was a bit pricey but i dont care) rewire and solder everything according to the nissan wiring diagram and put it back in (either get custom made panels to fill the sides or just use foam and paint it black).
Or just go down to autobarn/repco - get an R34 -> ISO plug, and then get the appropriate ISO plug for your headunit and not worry about soldering at all.
(If you're really bored, you could just take the R34->ISO plug and at least use that to adapt to the headunit wiring, so you're not cutting factory wiring)
With regards to using custom made panels or foam - do it properly. Get the right air conditioner panel, the right nissan-provided panels. They're really not that expensive, and you get a proper finish. You have a Nissan Skyline R34 not a $500 sigma wagon with 450,000km on it.
I took the second option with mine originally - but I've been doing stereos for over 10 years. R34->ISO plug, chopped the ISO off, solder and heatshink onto the headunit loom. No cutting of factory wiring, and no dramas.
Since then and moving to a carpc setup, I've modified it so that the speakers go off into their own plug, and that plug hooks to the speaker output wires back in the custom amp shelf in the boot... I like things being nice and tidy. Ideally for better signal I would run my own speaker wiring, but eh .. lazy.
exactly. what you have now done it make a giant mess of things. the byproduct of course is that something doesn't work.
JRM,
I have a strip/refit to do on thursday. once done the system will play DVDs, have a working sat nav that talks via the drivers dooe and a reverse camera. customer did not opt for digital TV.
  • 1 month later...
Yup, it's definitely possible, many people have that conversion.
Turbo or NA, both works, it's just that if you put it into an NA, it will only show throttle, rev light, oil temp, injectors, voltage.
But a MFD (multi function display) is costly, can cost anywhere between $600-$1000. I just sold one without looms for $600.
Here's a pic of my R34 GTT interior.
Awesome mate,all your interior panels.Is that real carbon fibre ? How much did it cost you to get and install that MFD ?
Also where did you buy your steering wheel,I've been searching one for ages and most of them comes without an airbag which is illegal ?
Thanks
Edited by Jeremy1607
that is DI Noc from 3m not real carbon fibre. I can get some below retail and might be setting up a group buy of it soon.
there is a few other options real carbon
or hydroprinting carbon I can supply photos of all the above.
and 3M has new products in the line up as well.for 2011
GREY,
this is what it SHOULD look like.
understand??
chris that looks amazing, i've already finished mine, but unfortunately i did a rough job on it, how did you get those custom panels at the two sides? as it is a non turbo i'm not going to pour money into it
The custom panels aren't actually custom. They are the factory standard double DIN facia and sleeves from a non-turbo 34 that didn't have the navi option.
Also, Chris did a bang up job with this instalation, I should know as that's my car :)
boz,
ta!
I have a S15 to do the EXACT same thing to next week. he WANTS the popup screen in the dash area with navi and TV and a camera. I'll take a few piccies of that one when I do it.
  • 2 months later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
