  • Replies 72
Posted Images
fair enough.. so i want to change the headunit but my r34 is different to most.. what do i need to do just to change the head unit, most likely chuck out the stock tv thing and would you recommend anyone in melb ?
well this is what i did to mine, i just removed the headunit (radio bit but can be any bit of it u want) then unplug the back cables (takes some skill u gotta find this button and pull hard, you might break a finger nail in the process) find a headunit you like either online or at your local car audio shop (i got mine from autobarn which was a bit pricey but i dont care) rewire and solder everything according to the nissan wiring diagram and put it back in (either get custom made panels to fill the sides or just use foam and paint it black).
Or just go down to autobarn/repco - get an R34 -> ISO plug, and then get the appropriate ISO plug for your headunit and not worry about soldering at all.
(If you're really bored, you could just take the R34->ISO plug and at least use that to adapt to the headunit wiring, so you're not cutting factory wiring)
With regards to using custom made panels or foam - do it properly. Get the right air conditioner panel, the right nissan-provided panels. They're really not that expensive, and you get a proper finish. You have a Nissan Skyline R34 not a $500 sigma wagon with 450,000km on it.
I took the second option with mine originally - but I've been doing stereos for over 10 years. R34->ISO plug, chopped the ISO off, solder and heatshink onto the headunit loom. No cutting of factory wiring, and no dramas.
Since then and moving to a carpc setup, I've modified it so that the speakers go off into their own plug, and that plug hooks to the speaker output wires back in the custom amp shelf in the boot... I like things being nice and tidy. Ideally for better signal I would run my own speaker wiring, but eh .. lazy.
exactly. what you have now done it make a giant mess of things. the byproduct of course is that something doesn't work.
JRM,
I have a strip/refit to do on thursday. once done the system will play DVDs, have a working sat nav that talks via the drivers dooe and a reverse camera. customer did not opt for digital TV.
  • 1 month later...
Yup, it's definitely possible, many people have that conversion.
Turbo or NA, both works, it's just that if you put it into an NA, it will only show throttle, rev light, oil temp, injectors, voltage.
But a MFD (multi function display) is costly, can cost anywhere between $600-$1000. I just sold one without looms for $600.
Here's a pic of my R34 GTT interior.
Awesome mate,all your interior panels.Is that real carbon fibre ? How much did it cost you to get and install that MFD ?
Also where did you buy your steering wheel,I've been searching one for ages and most of them comes without an airbag which is illegal ?
Thanks
Edited by Jeremy1607
that is DI Noc from 3m not real carbon fibre. I can get some below retail and might be setting up a group buy of it soon.
there is a few other options real carbon
or hydroprinting carbon I can supply photos of all the above.
and 3M has new products in the line up as well.for 2011
GREY,
this is what it SHOULD look like.
understand??
chris that looks amazing, i've already finished mine, but unfortunately i did a rough job on it, how did you get those custom panels at the two sides? as it is a non turbo i'm not going to pour money into it
The custom panels aren't actually custom. They are the factory standard double DIN facia and sleeves from a non-turbo 34 that didn't have the navi option.
Also, Chris did a bang up job with this instalation, I should know as that's my car :)
boz,
ta!
I have a S15 to do the EXACT same thing to next week. he WANTS the popup screen in the dash area with navi and TV and a camera. I'll take a few piccies of that one when I do it.
  • 2 months later...
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
