if thats the same one that was posted on here ages ago its been there for a while, the engine is made by impul with very little more power then the 25de, it came out of a 32 which had full gtr running gear, very rare engine.
there's a complete autech RB26DE sitting in a yard in Okinawa going for 4k (buying price in japan) according to the local car trading newspaper... altho by the you brought it down here it'd probably cost more.
I remember reading about this YEARS ago in Wheels or something...
It was an Autech-produced car, as Nismodified stated, and it was basically everything the R-32 GT-R was, bar the TT's. I think (not sure, so don't quote me on this) it was even a 4-door, and as you'd expect, it looked HOT!!!
Seeing that car waaaaaayyyyy back then (early '90's) started my love for the '32 four-door... :rofl: :boinkcar:
there's 2 autech's in the R32s... the 4 door GTR (4 Door Sedan with entire GTR running gear) and the RB26DE model. and no the engine and drivetrain is completely different to the GTR (ie no ATTESA, no AWD)
Guest
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
