The Autech R32 "26" was a bit of a fizzer in my opinion. It was a pretty boring looking R32 with less power than the GTS-t Type M at almost twice the price new. They were also all autos.
Not everything Autech does is gold. They also produced the R32 "Driving School Sports Sedan" version which was about as base model as it gets.
lol yeah got the brochure for the driving school one...
BUT it comes with 2 sets of pedals dude lol... i wanna own one of those... actually no, my mates will always press the accelerator when i go past cop cars n take corners.
Autech just makes speciatly cars, ones that factories don't make, but the public wants. Its not necessarily a sports tuner. Tommy Kiara, Impul and Nismo on the other hand are sports tuners.
these look liek and interestign engine
there was one of these car for sale on yahoo ages ago they were auto and 4wd and 4 door. 250 shouldnt be hard with a few tweaks ie cams etc
Water cooling serial 6 cylinders * DOHC Cylinder
Inside diameter x distance mm 86.0×73.7 Entire aerodynamic volume displacement cc 2568 Compression ratio 8.5 The highest output
PS/rpm 220/6800 Largest torque
Kgm/rpm 25/5200
  • 8 months later...
Interesting engine.....
Compression wise is still the same with the RB26DETT?
If it does, I wonder if It drives.
It's a nice rare engine. But I don't think it worth the price since now adays you can get a newer engine fron Nissan (even in NA) that has meet the 206kw japanese limit (on paper).
  • 3 years later...
  • 1 year later...
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
