Not necessarily, he won't max either the stock injectors or afm with the stock turbo so not much point splashing coin when it isn't needed.
guess so but if the plan is to upgrade to bigger turbo might aswell do it all at once.
As im guessing its not as easy to setup the nistune for injector and afm unlike the pfc
  • Replies 63
Actually injector and afm swaps couldn't be easier.
For injector swap just enter and old injector cc and the new cc and the nistune software makes all the adjustments for you, just need to do some fine adjustment of the Kconst and latency with a wideband.
AFM is the same, tell the software what the existing AFM is, and what the new AFM is and it makes the changes for you. Once again you just need to do some fine tuning with a wideband.
Just to clarify something, "headers" aren't really an upgrade for turbo cars as it's not as simple as bolting on a set of extractors and off you go.
The standard exhaust manifold is good for up around 300rwkw and generally an aftermarket exhaust manifold is used for a big turbo with an external wastegate.
Your first port of call should be a decent fuel pump and a full, turbo-back exhaust, boost tee (or electronic boost controller) then NIStune and a tune. That should net you close to 200rwkw and you can get used to driving it with some more power. By that stage you'll be needing to get the minor shift kit in to the auto and then you can look for a turbo upgrade.
I can take you for a ride in the wagon if you want, for all intents and purposes the engine is a 34GTT setup, it's just a bit heavier and is 4WD when I want it to be :)
Where about do you live ? Maybe I could bring my car for you to look at ? Haha
Because I think I have an aftermarket exhaust already but not sure what kind or type.It looks like this (ignore my reflection,just washed the car.It looks very shiny haha).
This is what the engine looks like (attached),everything is pretty much stock.Just a podilter,front mount intercooler and the boost set up to 11PSI.
Thanks !
post-79744-0-57631700-1300953557_thumb.jpgpost-79744-0-98477800-1300953565_thumb.jpgpost-79744-0-61805200-1300953575_thumb.jpg
Edited by Jeremy1607
looks like you definitely have a catback exhaust (rear part).
take a photo of the exhaust underneath the car, all the way so we can see how much of the exhaust needs to be done.
I did the full exhaust, intercooler and nistune first and made 190rwkw. This was a great setup. You might be happy here, well at least for a while. Then look at the next step.
^^this.
Thanks !
I'm in Ashfield mate, just east of the city.
As Harey said, you've already got at least a catback. You've also got a front mount and some more boost, need to sus out whether the fuel pump has been done as well.. kind of hard without pulling it out of the tank!
So really, NIStune and start saving for afm/injectors/turbo.
Plus a hi flow cat and dump pipe most likely.
Chances are the fuel pump is standard. My standard fuel pump was fine even after it was tuned at 190rwkw. The R34 pumps seem to be pretty good and enough for the standard turbo.
Yeah sorry, forgot to say if it's only a cat back then a nice dump/front and a highflow cat needs to go in there too.
As for the fuel pump, I think it's more a case of them not being as old as R32 and R33 pumps but for piece of mind when pushing for more power, needs to be done.
I think I have a full exhaust system but not sure.You guys can be the judge haha.
Here it is...
post-79744-0-21917500-1301031727_thumb.jpgpost-79744-0-01486500-1301031739_thumb.jpgpost-79744-0-09296000-1301031747_thumb.jpgpost-79744-0-11729700-1301031754_thumb.jpg
Looks like a standard front pipe and standard cat.. Jump on justjap.com or similar, and look for a one-piece bellmouth dump/front and a highflow cat (steer clear of cheap Xforce cats).
As for the bodykit.. I believe that's a Z-tune kit.. fkn $_$
Edited by bubba
Do you where to get a smaller size washer bottle ?
Wanna fit one instead of the stock GT-T bottle (which is bigger) due to having less room after fitting the intercooler kit with cross over pipe.
Nothing off the shelf that I know of but someone like Embleton Engineering should be able to knock you up a neat little ally bottle.
About the same cost to get 250kw as 290 300ish just more lag and different parts eg different turbo, better clutch etc. So you need to decide on your own how much power your going to want and upgrade the usual bits to handle it. Plenty of results/ dyno graphs it the turbo upgrade thread.
Plenty of people asking "what do I need for 250, 280, 300kw etc" and plenty of answers to these questions...
Find these threads and start with the supporting mods first otherwise you will have to pay for twice as many tunes.
  • 4 weeks later...
Okay,finally after I've installed the Nistune ECU and tuned it.
To start with the modifications,I was thinking to buy all these other supporting items as follows :
Z32 AFM
Sard 650cc Injectors
Walbro 255LPH Fuel Pump
X-Force 3" High Flow Cat
JJR Bellmouth 3" Dump Pipe
Please give me any tips or recommendations that you have before I go ahead with my order ?
A z32afm reads the airflow and sends the info to the ecu. They are used because they can read more flow than the stock afm.
An Apexi SAFC adjusts the signal from the afm in order to try to acheive better afrs - a task much better left to the nistuned ecu.
Consider getting one of the new Deatschwerks pumps instead of the Walbro.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
