Just wondering if anyone could tell me what is the difference between r32 gtst (sumitomo) and r32 gtr/ 33 gtst calipers to allow the larger discs? I did do a search but had no luck. I know you can get a spacer to allow the larger disc with the 32gtst ones but I was trying to avoid spacers and they seem pretty pricey for what they are.
https://www.sau.com.au/forums/topic/357586-r32-brake-calipers/
yeah the caliper mount lugs are different. obviously the GTR ones are longer so accommodate the 296mm rotor over the GTST 280mm rotor. getting a spacer to convert from 280mm to 296mm is not so great as it's only an 8mm change in radius, so since the spacer is so short you have to offset the caliper. my advice is either get 32 GTR calipers (pretty cheap) and run the 296mm rotors, or keep your GTST calipers and get the caliper spacer to run R33 GTR 324mm rotors. that is a nicer upgrade with a rotor that is quite a bit bigger than the GTST rotor.
yeah pistons and seals available from nissan. you can get a rebuild kit which is seals and dust boots pretty cheap. alternatively buy the project mu 32 GTR rebuild kit. it comes with nice alloy pistons which are lighter and a seal kit too. from memory it's around $400 for the full kit (includes 8 pistons). it's good value and will mean your calipers will be like brand new again for $400 and a few hours work.
  • 2 years later...
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
