I've recently changed my gearbox and the new one came with a longer shifter with a smaller socket and nylon boot. The increased length means that the leather cover no longer fits (lifts the plastic surround) and the gearchange is a longer throw.
Note from the picture that the new shifter (shown on the top) is longer both in the black body and the silver arm as well having a smaller socket. The socket size difference means I can't fit the old shifter back on.
Any ideas as to why there should be different models and how I can go back to the origial setup?
https://www.sau.com.au/forums/topic/357604-gt-r-shifter-types/
Unfortunately the socket of each is a different size. The original shifter(bottom in pic) has a socket larger than the top socket/bush combined.
The outside diameter of the nylon bush is the only difference I am aware of. We have swapped the nylon bushes over many times.
There is a difference between RB25 and GTR, though, so you may have an RB25 shifter or vice versa.
Let me get this straight, you have changed an RB26/RB25 gearbox for a RB20 one? Why on earth would you do that?
I bought a reconditioned GT-R box with an OS gearset fitted. It came with the longer shifter (smaller bush) already fitted.
I'll double check the socket again, but I'm pretty sure the ID of the bushes are also different (i.e. the sockets are different diameter).
Thanks for your help so far.
the GTR bush should be the large one.
So if it's a GTR box, the smaller bush should not be able to fit the GTR gearbox.
Failing that, take both bushes off and try to swap them, if the larger bush will not go on (requires a lot of force and you need to pop it in at an angle) then go down to your local nissan and buy the RB25 shifter bush which should fit directly (but it's larger like the GTR one so I don't know if you are going to run into trouble there.
I still can't get my head past the smaller bush, it shouldn't have a small hole in there in the first place
that is a weird one! love to know how you sort it out.
I reckon I know what's going on here now.
The shifter that came with the gearbox (which I now assime is either an RB20 or SR shifter) definately accepts a nylon bush around 5mm diameter smaller than my old GT-R shifter as per the above pics.
So....when I have a look at the gearbox socket that accepts the bush, there appears to be a sleeve pressed in that reduces the socket diameter by (yes, you guessed it) 5mm.
So......If this is the case what the previous owner has done is mada a modification that allows a taller shifter (i.e. comes to hand easier from the steering wheel and back) without affecting the throw. Apart from the leather boost sitting now slightly lower, everything works well and changes smoothly.
BTW - I did try to remove the sleeve using long nosed pliers, but it's in there well and good. I'll consider if I try to remove it next time the gearbox is out.
Well I don't know what is going on down your way but the shifter actually goes in to the transfer case (gtr) and not the gearbox as the transfer case bolts to the gearbox, Did you get another transfer case with the box, the smaller bush is for a R34 the larger bush is R32/R33
Dave
Dave
Referring to the gearbox as a whole unit.
Sry for hijacking the thread.
How difficult/easy is to access and replace this nylon bush - can it be all done from inside the car.
Does this nylon bush require replacing, do they get worn - reason why I'm asking is that I'm just chasing some more "feel" when I'm changing gears and just wodnering if new bush would provide me with a more solid shift-feel.
    • What a wonderful journey to read. Loved the photography. Literally found this an hour ago and couldn't stop reading, plus checking out a couple of the links. Was interesting as you had a few mods very similar to my sons Gtt, including the sheetmetal homemade V-Spec II rear diffuser, can't be too many of them around the world. Only to find it sold about three weeks ago. Well at least I won't have to keep re-visiting for updates. Anyway, well done on not just the car but the well written story and descriptions, and of course the pics. Good luck on your next one. Rob
    • Forgot to update. I ended up removing it and found out that it's dead. The car seems to run better than it did, although I haven't driven it hard yet. Literally just a flow restriction.
    • Sounds like the rack seals blew.
    • ^ This is all good advice. I can imagine that there's some passive components in the HVAC controller that run that PWM output that could die, or suffer bad solder joints. It can be worth opening it up, taking a schmooze around looking for swollen electro caps, evidence of liquid escape anywhere, tracks that have been hot, lifted, cracked, etc. A DMM might not be suitable for seeing if the PWM output is pulsing. Might be too fast and too low voltage for a DMM to keep up. An analogue voltmeter might give a better hope. I use a handheld oscilloscope (<$100 from Aliexpress if you want something cheap). A DMM might see the voltage across the motor flicker. Otherwise, as above. If you can successfully see PWM action, then the control side should be good. If you can't see it with what you have, you might need to step up the instrumentation used, as above. Beyond that, and dbm7's advice on testing the motor directly, you're down to looking for broken wires, corroded connector pins, etc.
    • So Thanks for the comments etc. To follow up on this, we went down the path of fitting a divider down the middle of the external pipe that was added to the exhaust manifold and the divider went from very close to the external wastegate all the way up to the "V" part where the pipes from each side of the manifold joined. After this modification it was finally in a position to do the dyno-tune with some degree of success. Top end power was down about 10kw (250rwkw down to 240rwkw) I believe from previous but it seems to be more responsive lower down and at least it is now driveable and fun and back on the road to be enjoyed. Apparently the timing couldn't be run the same as it was running into knock and boost was down about 1psi. For all we know this could have been from the fuel being a bit older, or perhaps some slight complication from the new head gasket as we didn't have compression figures from before that mod to compare. I'm no mechanic and this is second hand info but I just wanted to follow-up to those that commented or read the original post with interest. After so many months of stuffing around this is a big win. The interesting part was most of the info around this was gained from information around Barra motors and not GTR as the manifold setup on the Barra with single turbo was more similar.  Thanks for those that helped with info. Regards Rob
