That's a picture from a GTR (you can tell as the climate control unit is slightly different) - but its the same as what most other models get that don't have the navigation/pop-up screen option.
By 'surround' - I'm guessing you mean the trapezoidal piece of plastic with the rectangular hole with the headunit at the top and the din pocket at the bottom (it also has brackets at the back for holding the climate control, and din pieces in-place).
These parts often come up on crashed cars in the 'for sale' section. If you need to swap the parts over you shouldn't have long to wait for parts. Alternatively, try your local japanese/import wrecker.
that is the same part and a/c unit the series 2 GTT come with that have the tv option. if that helps
you can find some in carbon fiber from japan but they still won't fit some radios without a few tiny mods, to make them look perfect fit
you can buy them from wreckers, or import.
or make your own easy.,
might be able to order one from nissan still ? if you want to pay a premium and shipping from japan
that radio could be mounted cleaner , so the gap would go away. or just drop in a double din radio ?
Edited by sapphiregraphics
I have the same climate control as I want to get rid of the old navi system.
local jap wrecker or me. expect a $300 bill either way.
$300 really? far out, I might have a look around and if I can't get I might be asking you for one.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
