Purchased this car back in august 01 for a whopping $23K as a 1st owner in Australia car.
Car has been through alot of changes and been subject to my learning car stuff by tinkering with her since i bought it. This is one of the reasons i have decided to redo the whole car from the ground up as there was too many "just make it work" moments in the past and this led to the un-neat solutions that this attitude creates. Im sure we all know what thats like.
car was purchased with :
Volk EMU racing 16" rims
tanabe coilovers
HKS SLD
Black s1 M spec kit
Will try to find some old photos of the car when i bought it and post them up later
Here is how the car sits right now :
HKS GT3040 on stainless manifold
Tial 38mm gate
custom exhaust
sard 550c injectors
Sard FPR
044 externally mounted
Power FC
Z32 AFM
Tomei Poncams
Plazmaman Plenum
PWR radiator
making 290rwkw some years ago after i finished the install on hitmans dyno on 98ron
Been through a few changes over the last 5 months also with the addition of Tein Flex coilovers and removing the subframe and replacing all the bushes.
Car now :
Plan for the car is to get it ready for engineering and also make it more comfortable and reliable, then get back out on the track :)
https://www.sau.com.au/forums/topic/357621-craved-revamp/
  • 3 weeks later...
  • Replies 184
Posted Images
hopefully keeping this thread updated will help me with the motivation to get stuck into this rebuild. Even if i didnt know it had been approved already lol
Brake Kit :
Consists on EVO IX brembos
Custom 355mm rotors on alloy hats front and rear
Rear calipers where spaced apart 4mm to allow for the 32mm thick rotors - allowing for a more common thickness rotor for cheaper replacments
rears - and the reason i had to sell my work meisters :(
no room for the caliper in there :P
Hence the 350z rims - picked them up for $200 off ebay, so got them coated up in Black chrome and it turned out to be a real nice combo with the cars colour and the rim design. Its not flush but goes well with the $300 semi slicks i picked up 2nd hand from Gordon Levin Tyres.
Advan AO48 - 235/40/R18
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5746211
At the end of last year i took out the rear subframe for a big overhaul - New bushes everywhere, from subframe to arms to the 2way mechanical diff mounts
Split down to this:
Then fixed up and turned into this :
With the alloy rear hat it will the extra cooling provided by the 2 piece rotor, but i lose the ability to use the handbrake while in motion - so no sliding that way for me
Hicas lock bar was finally installed when this was all re-installed into the car
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5746246
so heres the old interior, fibreglassed in that boost guage and had the oil and water temps replacing the old hazard lights and demister switches. idea with those was to be legal while more in line of sight than the DINN console
Then i got these :
and after having this car for so long, dealing with rattling pillow ball tops and fuel pumps in the boot i decided i wanted this car to be comfortable to drive, while having plenty of power and as good handling as i can get it.....so i did this
So to match the new R34 GTR seats i got the door cards and rear panels retrimmed in as close a match as i could find.
The seats i got were modified to fit some non-skyline so i had to cut the mounts off the stock seats and weld them back onto the GTR seats - still only done this for the drivers seat so far
Rear seats were also installed from a 34 GTR
new front seats changed the driving position, so i purchased some deep corn to resolve the issue :)
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5746247
Powdercoated my own set of RB26 covers while i was prepping some other parts (been sitting in powder primer waiting to go for near 2 months) , really like this colour
Love how the RB26 looks
So after some thinking about engineering and the work i need to do with piping and ceramics on the hot side i've finally decided to build my RB26/30
Only bits left to get are :
AAC and IAC
Injectors
new PowerFC - hoping to score a D-jetro
New Exhaust Manifold
Oil pump
Crank Collar
VRS kit
everything else i have already collected - so hopefully i can get the crank collar soon and installed on the crank asap
then i'll be assembling the motor myself, nothing fancy just rebuilding the rb30e block to standard as im not after big power, just a bit more drivability.
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5766101
cheer mate,
re: handbrake
Im using a 2 piece rotor on the rear. specially made rear alloy hat is hard annodised for durability, but still cannot withstand the use of the handbrakes shoes on it while in motion.
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5766188
How did you find that sound deadening idea worked? How much and where from?
Without the rear seats in my R34 transfers a fair bit of road noise through the cabin... :glare:
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5769089
i got a mega pack from the USA, was a long time ago so dont remember the price now
as for how it works, well i havent driven the car since doing it haha
i did notice that from doing the front half of the rear quarter panel (under the 1/4 window) that opening and closing the door has more of a thump to it than before. thats without touching the front doors yet
i have 2 sheets left out of the 9 sheets in the pack which did the 1/4 guards and the rear seat area you see in the photos. I think to finish the front half of the cabin and the boot i'll need another 2 boxes.
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5769104
I used my friend :google: and i found the company in the US... They have a new version called the SUPERLITE which is an obvious advantage for the performance side.... They have prices online for the pack similar to yours and its about $350 USD (Not sure about freight though)
If it gets rid of the road noise it will be worth doing...
What do you mean by "More of a thump"? is it just because you sealed it up and its airtight?
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5769121
Just less reverberation when shutting the door, like nice new cars
checkout ebay US too for the dynamat, definately cheaper than buying locally even when the dollar wasnt as good as it is now
https://www.sau.com.au/forums/topic/357621-craved-revamp/#findComment-5769131
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
