Craved - Revamp
Nearly 2 months on, but i finally have my speedo sender, arrived today and is installed and WORKING!!
hard to tell how much the power steering coming back has changed things, as i have different wheels, different steering wheel and HICAS removed.
atleast when i get it rego'd i'll be able to drive it around a bit and get some road tuning done.
  • Replies 184
  • 2 months later...
Spent a little time on this in the last 2 months, though not enough :(
Car is rego'd and running on the road!
took the car out for a few drives and was blowing IC hoses - easy fix with welding on some beads to the new alloy piping i made
Car is running better and better everytime i take it out. Fiddled with the tune and did some logging with the datalogit - ended up adding 4 degrees of timing in the off boost area with only 3 cells reporting 15 or 16 knock in the logs - just have a loose connection in the wideband setup that stops it working every now and then. probably something i did when i was hooking the PLX SM-AFR up to the datalogit unit.
Anyway, it feels much faster than my stocker 33 for normal road driving, as any boost really does send me over the speed limit lol - think i can get to about 3psi before im speeding haha
best thing - its so quiet!!! (well except the exhaust) - no rattles, no knocks just a little scrubbing on the stock rear guards over bumps, so a quick roll of the guards should sort that out.
Cheers Dave - chop chop :P
time to finished the interior for me though
Ah well I have already finished that part of mine.
BTW more coating to be done soon on a new strut brace. Friggen C/F bonnet won't shut with teh nismo one :(
Looks good man, I need to talk to you about an idea I have with the brace anyway so no hurry.
I'm thinking of a HKS Kansai copy, but dunno how we can pull it of maintaining the nismo mounts
  • 10 months later...
Cant believe how long its been already - hoping to get a bunch of stuff fitted for the cruise on the 30th - see how that goes
car needs some tunes, so a mount for the Amp needs to be fabricated asap.
Wow! Been ages........... i wanted to make that cruise but will depend on how the car is running with the issues.................
SO much positive feedback from your handy work ;)
nothing new, i havent had time to drive it since i got it home, jsut in and out of shed a few times lol
time for fresh fuel, new fuel surge tank, amp mount and some street tyres on another set of 350z rims i bought.
its been pretty crazy after moving into my new shop and expanding the services i provide into the domestic and commercial/industrial market.
but now i've had some time to get working on my own things again.
newly coated bronze 350z rims with some federal 595's for street duties
Then in prep of getting my 26/30 finished one day i figured ill spend on a known commodity of a 6boost manifold - designed for the 26/30 but with a 25/26 flange pattern so i can get it installed on the RB25 and only have limited changes to make when the motor is built and swapped over.
upgraded from the tial 38mm wastegate to the turbosmart 50mm item, the old setup had the gate hanging right down at the chassis rail via some adapters etc, never caused any issues but wasnt as neat as id like
got some time to perfect the surge tank design, my original fabricated one was around 4.5L and overkill.
new one is 2L and alot tighter to the car and will weigh less and is easier to replicate if anybody would want one.
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
