next job to complete at this point is the radiator shroud for a thermo fan, this one is incorporating a cross over pipe within it for a legal spec catch can arrangement on the drivers guard that will feed back to the air intake without running a long ugly hose across the engine bay.
  • Replies 184
Posted Images
thanks Duncan, shop was a huge undertaking and a big step up - 7m long oven ready for doing full chassis etc
ETA? haha that depends on how busy i get, hoping to have the new dump pipe finished off this week, that could get her back on the street if i just leave it at that.
but that never happens, besides, once shes up on the hoist i keep finding new things to do/fix/improve upon :D - having a hoist is both blessing and curse :rofl2:
Ended up flat chat last week, so it got delayed again.
New dump is almost completed, just need a long die grinder bit to clean up the inside of the merge a little, then i can weld the rest of the wastegate dump up. Still unsure whether i'll need to run another vband on the WG dump to assist with install, got one on order but ill test fit it without and see how much of a struggle it will be.
Also removed the turbo's water return from around the back of the head, going in favour of a solid line running around the front of the head ready for the 26/30 install. Removed the water feed from the plenum/fuel rail completely and blocked it off behind the thermostat.
another couple of steps....
test fit of the new dump pipe worked perfectly, so rather than remove it to finish the welding i thought i'd dummy up all the lines for the turbo.
New hard line is run around the front of the motor and will connect to some new -8 fittings in the turbo and hardlines with tube nuts.
Old drain still works, just needs to be shortened slightly and the old oil line fittings in the block worked great. just need another metre of the -4 teflon braid to move the turbos oil filter up into a serviceable area.
getting all this sorted out, means i can head straight to ceramic coating everything the next time it is removed and the dump pipe is sealed up with the TIG.
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
