  • Replies 184
Posted Images
I've seen the rears and I couldn't see any gaps, looks to be a good fit.
Hey Chris what size gauges can you fit in the din pocket spot? I remember seeing somewhere a triple gauge holder the has the gauges tilted towards the driver but I can't remember where. Might save you some fabbing. I'm thinking of doing the same thing for oil, h2o & ???? Maybe boost?
Now teach me how to weld will ya!
I have my boost gauge down there, and there is a MAJOR problem, it's WAYYY out of your peripheral vision.
Either on the A-Pillar, or in the cluster/above/beside it.
Down in the console is wayyyy too far out of view.
love it mate , really god progress so far :)
the seats look sex
cheers, right place right time with those, alot more work than just bolting them in for me since i had to weld on the mounts from the stock seats, but a bargain is never a bargain... but i could fix it easy enough so its still a bargain :)
what steering wheel is that? the car looks awesome too, love the 34 seats.
Yeah its a nardi deep corn. pricey bits of gear - picked it up from the tuners group.
How well did the rear seats fit in? Just bolt straight up? Any noticeable gaps/overlapp where they don't line up properly?
there is a small gap at the very outer edges of the rear seats between the back rest and the base, probably 10mm- i'll just have to put some black fabric/carpet behind there as the dynamat's reflective surface makes it more obvious if you are in the exact right position.
i'll be running 2 1/16 inch autometer guages. Cant justify the cost of DEFI's etc at this point since i already have the guages. autometer also have angle bevels for their guages, so can run them to help increase visibility - thanks for the reminder, have to add them to the list lol - the only premade DINN slots i have seen have been heavily staggered and dont really look all that neat in my opinion.
I can teach you to weld if you like, just let me know when you need a lesson, or have something you need to build
Fair call, but other than in the illegal positions there is very little room for guages. As you can see in the old pic of the interior i did make an attempt at moving guages into more visible positions. However, if you cant take a little time to glance down then you are too busy driving and shouldnt be looking at guages lol
ID3 has some boost logging capabilities and i never really looked at my old boost guage - 7 on the stock guage is approx 1 Bar, if its less on the guage then i have an issue, overboost has a warning on the ID3.
I'll be setting up a series of hobbs switches linked to displays while im building the 30, so it can tell me if there are major issues going on anyway
hopefully i can keep up with the work on it as i try to fit everything into this 3 day week, will see how we go :)
Quite true there Chris, I keep thinking more in terms of track vehicles, where as you're in the street build side.
On the street it won't be too bad, as you're not hounding it.
I'm going to be remounting gauges up in a more "visible" area in my peripheral as I'll be tracking it alot.
if it was a track car i'd rip out the stock speedo cluster and make my own
hopefully lights, buzzers linked to hobbs switches will be enough to warn me. they can be a little annoying on start up though haha
Mona, stay away from my seats :P
Chris are you going to be putting the standard tb on there for your dummy startup?
The reason I ask is I wanna see what you do with the coolant lines into the bottom (or top when inverted) when using the plazmaman.
Btw my intake mani is heading your way soon for more chrome coating just gotta clean it up. Told you I'd find more stuff!
Looking good dude
Looking good dude
cheers
you dont need the water lines to the TB as there is little chance of the TB icing up in cold weather :P i just used some pliers to wiggle the fittings out of the TB body.
I got a couple of rb25 runners at the shop, so take a photo of yours and send it to me so i can be sure its the right one (apparently there are some differences)
What are you doing with the 3040 when the 26/30 goes in?
Hint hint ;)
keeping it lol
rb25 = 291rwkw on 18 psi with the poncams, so should still be enough to run on the 26/30 and make the 300rwkw mark without too much effort.
i have the 0.87 and a 1.12 rear housings so flow wise it shouldnt run out with those options, but i just want it more streetable at this stage so the 0.87 will stay on we'll see what it gets
oh yeah Dave, the engine bay is almost back together now so you can see it running in a week or so
Also while it looks strange with the 2 lots of silicon off the turbo outlet, the blue pipe is a 2.5 to 3 inch reducer, got my delivery in from JNT performance but didnt want to waste one of the alloy reducers i got until i do the final piping on the 26/30. I'll have to upgrade the exh manifold for the 26 head so most rb26 manifolds sit the turbo more forward than this one ( flange is behind the centre line of the runners)so both intake and outlet will need to be changed
Next:
  1. strip down all the piping and clean up the insides of all the pipes
  2. got my new 0.6 rollers for the MIG and a new gun and lead (currently setup for Alloy MIG welding) - so weld up the pipe pass throughs and finalise the front reo welds
  3. make supports for the rear of the front bar
  4. re-run vacuum hose to the boost controller from the plenum - old setup had nipples on the turbo outlet pipe
  5. make a plug for the Pcv holes in both plenum and cam cover
  6. connect up inlet pipe
  7. start it :P
Damn lol
Should be good :)
haha - they make good power on the 1jz motor too - mate used to work at ASA and they put one in an IS200 that had the same GT3040 on it and it was easily over 300rwkw.
have seen them still for sale, think they are well under the price i paid for mine 7-8 years ago lol
I'll send you some pics tonight mate, I've got to get of my ass and update my build thread anyway. (not that I'm as far as you, only manage to take things off so far lol)
You do know that I'll want it all smooth and stuff don't you? :)
Sent my RB30 block off to get machined at Windsor engine reconditioning. full engine clean, hone and removal and grub screwing of the oil gallery plugs.
got it back yesterday so did some work on it til late last night
Lick of paint
Then some threebond and installed the welch plugs
Then dummy assembled the motor to check the clearances with plastiguage
running 3 thou clearance on the bearings.
Block went back to windsor engines today for decking after the paint process was completed. Also sent over the crank this time for machining for the crank collar, grub screwing and a polish of the journals.
Took some time tonight to weld up the chassis passthroughs in teh engine bay now i have the 0.6 wire and rollers etc.
Quick grind witha flapper wheel, then a coat of rattle can paint for the moment. will smooth it out and get the rest of the holes welded up once the motor is removed.
Will work on welding the sump this week for the oil temp sensor, get that coated up ready for final assembly when i get the block and crank back.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
