  • Replies 184
Posted Images
Looking good!
Love the dimple dies, I want some!
Cheers :) its getting there, just cant wait to drive it around again - but i know you know that feeling lol
ebay search the following to get the set i got : 7pc 4140 Dimple Die Set (#160548222631)
Chris the car looks fantastic,,,you have sold me on those wheels,,,they suit the car perfectly. Screw the weight thats the wheels I'm buying.
Two questions if I may though
You use a circular saw to cut aluminium,,,never entered my head,,,I always use a jigsaw which is a pain in the arse. Do you use a particular blade???.
The dimpling tool I've always wanted,,,I would only ever use it on aluminum and it seems for best results I need a press. Is there another way of doing it or should I wait and make Mr Handley buy a press?.
Cheers
Neil.
Neil,
TECHNICALLY you need a different blade - that saw is using a regular old wood blade :P spray it with inox and away you go :D
i have a table saw with the proper blade, but the brushes crumbled cos it s a crappy titon lol and i havent got around to getting new ones - but thats the best way to cut a nice edge.
Dimple dies, you can use a vice for alloy, but these cheap presses are much easier for one man operation, plus the vice jaws mark the tops and im protective of my tools lol
started coating up the mesh in the bar in satin black last week when i was doing some other stuff, hopefully get that back on sometime in the near future, just too busy these days
Car spent the day getting a wheel alignment from Wholesale suspension in penrith - helpful guys and good setup for the low car
turns out the front caster rods are seized so couldnt be adjusted, so ill have to address this
cars driving great, would be better if my speedo would work and in turn power steering but still easy to drive.
next step is to swap with the spare caster rods and work on the adjustable ones - see if its worth putting new bushes in them or starting again.
and swap out the speed sender to see if that is causing the speedo problem - already rewired the ECU to fix up the japanese intrusions into the wiring and replaced the cluster with the nismo 300kph one so it shouldnt be them.
stock one is on the shelf now in lieu of the nismo 300kph one. speedo hasnt worked for a few years now lol
well it has actually, but only sometimes after a bit of a work out, and without fail at the track it works- so it makes it a bit harder to diagnose. really need some time on a hoist to trace wiring and swap out the sender unit
given me a thought though, might have to look at teh contacts on the back of the dash - as i believe it runs through the dash before it goes to the ecu .. hmmm
might as well try, forgot to remove the airbag light anyway haha
Its the sender lol - swapped it out with my daily's sender and work straight away.
heard a rumor that nissan dont sell them anymore ....
Good work on fixing it. I may have to check mine out.....lol when its actually running!
yeah dave, i had to go back in to get the hicas out
now i have to go in again for the airbag .. sigh lol
yeah michael, i was tempted to rip apart the sender unit and see whats inside that could cause the problem - but then it would have to stand still til i fixed or got another one - so i'll find a replacement then tinker :P
    • Good to see your rotors appear as rusty as mine šŸ¤Ŗ
    • Took it for a drive to do some logs, Iā€™m pretty sure my voltage issues and electrical noise issues are gone, Iā€™ve sent a log to Adam and am waiting to hear back with confirmationĀ  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4 Ā  idle video from that day just becauseĀ
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!) Ā  Ā  I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding). Ā  I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springsĀ  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
Ɨ
Ɨ
