Hey Guys just getting rid of a few things from my garage, feel free to make offers
For Sale:
R33 Standard Front and Rear Swaybars (with rubbers) - $40 for both or $25 each
R33 Open 6 Bolt R200 Diff (4.11 Ratio) - $60
R33 Drive Shafts (6 Bolt to suit above diff) - $40 for both
R33 Washer Bottle (unsure if motors work) - $15
R33 Stock Suspension Front and Rear (Average Condition) - $50 for all of it
SMALL Diff Back Exhaust (Good for Compliance) - $40
R33 Standard Dump / Front Pipe - $30
R33 Boot Lid Matt Black (No Spoiler, Lock or Hinges) - $30
6 x R33 Series 2 Coilpacks (All working when removed) - $80
Splitfire Coilpacks to suit Series 2 in box as new - $350
Lightweight 17' OZ Racing Wheels 8' fronts 9' rears with worn tyres (One rear tyre is brand new, tyre itself cost $350) - $400 for all
Bride Drivers Seat Rail, Super Low Super Long, to fit R32 / R33 and 180sx / S13 though one bolt will not line up - $150
Above rail can come with Recaro SR4 seat, very comfortable, perfect condition - $450
Brand New Aluminium Bash plate from GKtech to suit R33 - $110
Boss Kit to suit S13 (Can fit on a 33 also) - $40
All items are located on the Gold Coast, Robina Area.
Please contact me via PM and I will get back to you asap, leave your mobile number for a faster reply.
If you want pictures please leave a PM with your mobile number and I will MMS them to you.
Cheers
Edited by Binofski
https://www.sau.com.au/forums/topic/357631-qld-r33-parts-cleanout/
  • 3 weeks later...
is that dash mat to suit the s2 r33 with the passenger air bag? and any chance of an uncut r33 s2 front reo bar?
Dash mat does not have the void for the passenger airbag, however you could weaken it similar to other factory dash mats with a stanley knife.
Could you please post a pic of the r33 bash plate.
Thanks
No Problem, plenty of interest in bash plate, no one has dibs yet though.
what type of bride rail is it? side mount or low mount?
Rail is a low mount, it bolts to the underside of the seat.
All PM's replied
Cheers
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
