Thought it may interest you if you haven't started the rebuild on your current engine. The engine you were talking about earlier in the post (VK56DE) has been listed on EBay with a Buy it now of US$2500, 2006 build and only 5000 miles on it.
Look up EBay item no- 130092922424, not sure on cost of shipping it to Oz but worth asking about anyway.
  • 4 weeks later...
  • Replies 390
Posted Images
Cheers mate, had a look at that but im back at uni now so funds are limited.
Ran a 10.17 @ 131mph on weekend blew the head gasket... it seems we've reached the limits of the stock head gaskets.. i have some coppers sitting on my desk.. the block is off to be oringed all the good stuff from the old heads will be changed over to the new heads.. just trying to track down a set of rings and bearings and it will be back to the track.
Also the new torque convertor is flaring to something like 6000 rpm and therefore running very inefficiently once this is sorted i can forsee easy 9's, bring on the winternats.
Edited by NA_R33
  • 2 months later...
Quick update on the shitter.. block is back from Mendhams, rings and ring grooves in place, heads should be ready next week, there also getting a tickle up while at the machinest, just about to order rings and bearings and should have the stally back next week, so within a month she should be up and running again, bring on the 9's
Just finished reading this whole thread.
That is one awesome machine. U have done what most of wish we could do (extreme power and times with different engine swap).
Well done mate. Really looking forward to seeing what this thing has in store for us into the future.
Chris
he makes it all sound so easy doesn't he?
i've grown up with this car and seen everything john has done to it, there's been a lot of R&D, money, time and effort put into it.
easily competing with the top dollar dragsters in australia with a two man team (john & mechanic) and with a realistic budget!
good luck with 9s dude, will be there when you do!
No no that was quite correct, that was with a full exhaust, running ~5-6psi on 50/50 Pulp/Toluene, shes had a few changes since then :(
Cheers for the comments guys, Much appreciated :(
Rings and bearings should hopefully be here this week, so it looks like we may get a run at Jambo after all, should be interesting.
Im hoping to mate, i wanna come up for it, see u dip into the 9s been a long road since that week in ur pop's shed when we put that motor lol. its an animal now, remember u coming to grips with it being an auto to lol
Yeah for sure dude, i think were gonna be camping out there and when were not ur welcome to stay at mine and the trailer is plenty big while were out there.
Well i got ahold of some hard blok, so the block will be grout filled.. should hopefully have it running sunday, have been some delays with getting the crank ground... the workshop doing it couldnt find any specs on it, but thats all sorted now..
ooooo now were talking full race spec build
half filled or fully filled?
thats gonna need some massive water pump and hi flowing head
you ceramic coating the water galleries for better flow and less cavitation?
Hahaha, its coming its coming, the machinests have beens stuffing around with the crank and block its... still not done, should pick it up tomorrow, wish we had the machines to do it ourselves at our workshop, one day....
Its going to be a full fill and the water will just sit in the heads, it hasnt run a water pump for a while. It runs for less than a minute each pass... its fire it up, burn out, run and shutdown.
With no water pump the temps are no higher than 92 degreese (celcius) shut down at the line and creaps too 110 after heatsoak... Running methanol which cools intake charge temps and a colder combustion (to my understanding?).
for the others,
methanol (100%) is often used in anti-freeze due to its cooling nature, (low freezing point at -80ºC ish)
like you said it is more flammable with a lower flash point:
methanol flash point is around 10-11ºC
and petrol, depending on its mixture would be around the 40-50ºC mark i would guess?
just a bit of background in case anyone was wondering why he's doing what he's doing.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
