GDAY , i had all intentions of getting out to the Jamboree , but just .. excuses i wont bore you with them .
Am still interested in the auto box , ph me on 0423 546 380 .
regards
Don
Sorry gave you wrong ph no , its 0413 546 380 or work 32768781 or h 33799091
  • Replies 390
Posted Images
Any video's a good video :laugh:
Here you go John:
http://www.flexi.net.au/~waradsl/ska/john400m.wmv
(right click, save as)
Thanks to LazyBastard for hosting too :no:
I am not to sure at what stage this was in Blacky's life so I'll let you explain that.
  • 1 month later...
Hey mate,
Not sure where i was up to. Last time we took it out the stocko gearbox was finally giving up the goast. Mike from MV Automatics is just about finished the new Power Glide, built to handle big power, transbraked with all the goodies... we should be hopefully have it in the car and running this weekend. For the time being ive been focusing most of my efforts on finishing off the new fully enclosed trailer for the car.
With the new box, were hoping for some sort of sub 10sec pass, just how far were not sure yet. At the moment were looking into getting the offset changed on the rear rims to sit further under the guards and allow a taller tyre as we have effectively run out of speed in the top end. this combined with a 3.9 auto diff gears and raising the rev limiter should hopefully give us enough MPH to stop hitting the rev limiter before the line.
We will also be putting the chute on this weekend as with the extra mph we will be getting very close if not passed the 140mph parachute req'd mark.
Plans for the new engine are slowly coming together, but money is a little tight as usual with most around chrissy time, but i have been doing a lot of research and plans include:
VH45DE:
Custom Rods
Custom Pistons
Nitrided & Balanced Crank
Decked and O ringed block
ACL head gaskets
ARP headstuds and rod bolts
Port and Polished heads oversized valves
N13 GTiR Valve Springs
Custom Manifold
and the blower?? dollars permitting a PSI blower (same as what the fuelers run but a little smaller)
but yeah nothing to new yet, hopefully ill be able to report back next week with some new killer times, either that or ill be crying that i have destroyed the rear cradle in the car which is about to get a whole heap of reinforcement this weekend aswell. will try take a few more piccies of everything as it comes along.
saaaa-weeet
sub 10 sec pass on a stock internals engine is a bloody good acheivment
has it still got the original driveline (ie driveshaft and diff) - i would have thought that it gave up (specially the diff) long b4 u made a 10 sec pass
ohh - would a roots type blower work? or would that require a lot of custom fabrication
or is the PSI blower a roots type blower?
Edited by usherly
The diff is a nismo 2 way, and seems to be coping fine with the power, Try 09's skyline years ago still ran a standard turbo diff to get to where it did. Drive shaft stilll has the standard uni's and center bearing just adapted at the front to fit the infinity box. When the new driveshaft goes in it will be a beefed up condierably and if possibly, length permitting a one peice unit.
The PSI blowers a basically a roots style blower but require almost no horsepower to turn them. You can spin the pulley on the front back and forth without breaking a sweat which you simply cannot do on a weiland/holley/littlefield style roots blower.
nice - so does this mean supercharger poking out of the bonnet?
sounds like a pretty decent setup and plans for the driveline
Thats exactly what it means :ninja:
Well gearbox left adelaide yesterday on express freight so i should see it late this arvo or tomorrow some time, then it will be rush down to hardy and spycer to get the tailshaft made and a full weekend at the workshop, fitting and making new bits and hopefully we'll be out next weds or sat or both if there on at the Test and Tunes scaring myself again, getting excited now!!
Gearbox finally arrived today, looks awesome, will dummy it up in the car tonight so i can measure the drive shaft and send that off to be made tomorrow, getting really excited now...
haha, yeah. Bloody thing doesnt fit... have to trim some little wing things off it on the side near the back of the pan. Parachute and gearbox fitting on sunday, them some skids.. and then drags on wedensday, farken crazy excited!!
2 speed glide, tube fram front end has gone on hold until at lest the end of this season, we dont want to make to many changes to the car at any one time so we can keep track of how each change effects, advatages, or disadvatages the car and then go from there.
Edited by NA_R33
  • 3 months later...
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
